by raziko [OP] » November 12th 2013, 6:53pm
by DRZ » November 12th 2013, 7:16pm
by RECox286 » November 12th 2013, 10:48pm
by raziko [OP] » November 12th 2013, 11:01pm
DRZ wrote:I never heard of ATF in the power steering but there's probably a lot I haven't heard off I guess.
by raziko [OP] » November 12th 2013, 11:09pm
RECox286 wrote:Before P/S fluid became popular, it was common practice to use A/T fluid in P/S systems. IIRC, the two are compatable
and either can be used. The seals and hoses are impervious to both fluids. It's basically just a hydraulic system in
either case. If I was in the desert, and developed a slight leak, and had to take a leak, I'd put it in the reservoir til
I got home ! Any port in a storm ???
Uncle Bob
by astroman97 » November 13th 2013, 4:51am
by offroad safari » November 13th 2013, 4:57am
astroman97 wrote:I remember ATF being used in power steering pump s ....always wondered what would happen if you used power steering fluid in the transmission...no don't want to be the first to try it
by snapper388 » November 13th 2013, 9:13pm
by raziko [OP] » November 13th 2013, 10:03pm
snapper388 wrote:check the universal joints in the steering shaft they may be worn or binding.
by snapper388 » November 13th 2013, 10:13pm
by redfury » November 14th 2013, 7:18am
by raziko [OP] » November 14th 2013, 5:16pm
snapper388 wrote:check the hoses at the steering box make sure the lines are not twisted or kinked at the fittings.
by raziko [OP] » November 14th 2013, 5:19pm
redfury wrote:Did you make sure to bleed all the air out of the system? There is a procedure for doing so with the hydroboost system
by raziko [OP] » November 15th 2013, 4:11pm
by raziko [OP] » April 13th 2014, 1:41am
Astro Pop wrote:Any results?
It is currently March 1st 2021, 7:13am
Steering Forum |
Moderator: chevy57bert |
Previous topic Next topic |
Sponsors |
