by momof4 [OP] » May 27th 2010, 2:54am
by momof4 [OP] » May 27th 2010, 3:11am
by icebrrg3rd » May 27th 2010, 4:04am
by Jasen » May 27th 2010, 4:29am
by workinVan » May 27th 2010, 5:22am
icebrrg3rd wrote:under the front, and grab the idler arms. Shouldn't wiggle much up and down, maybe 1/8". Lift the front end. Grab a wheel at 3 & 9 o'clock and try turning it. Both tires should move. If you can move one and the other doesn't, it's not good.
-Andrew
by Astroplane » May 27th 2010, 9:24am
by momof4 [OP] » May 27th 2010, 2:04pm
Astroplane wrote:This issue could be brake or suspension related as well. Time to do a visual inspection of steering linkages or have a shop you trust do a complete inspection. Please ask us any questions you have before driving your van again. Include detail on any odd noises, sounds, smells, etc. Does the steering wheel seem to pull one way or the other when this happens?
by astroturf » May 27th 2010, 2:09pm
momof4 wrote:Astroplane wrote:This issue could be brake or suspension related as well. Time to do a visual inspection of steering linkages or have a shop you trust do a complete inspection. Please ask us any questions you have before driving your van again. Include detail on any odd noises, sounds, smells, etc. Does the steering wheel seem to pull one way or the other when this happens?
No funny sounds noises smells etc. I figured it wld be somethin costly. MAN I LOVE THIS WEB SITE tho! My dad used to do all my mechanics but a stroke last yr took most of his memory. I really should of been payin more attention all those years. Bein a single woman takin a vehicle in for a oil change they try to rob me like im a complete idiot. What is it w/ men tryin to rip off women when it comes to vehicle repair really???
by icebrrg3rd » May 27th 2010, 3:33pm
workinVan wrote:icebrrg3rd wrote:under the front, and grab the idler arms. Shouldn't wiggle much up and down, maybe 1/8". Lift the front end. Grab a wheel at 3 & 9 o'clock and try turning it. Both tires should move. If you can move one and the other doesn't, it's not good.
-Andrew
both front tires should move opposite of each other, ONLY if its awd, if its rwd then the front will be independant of each other
also take a look at the sway bar connection and make sure they aren't cracked or broke off
by castle_Rock » May 27th 2010, 5:49pm
momof4 wrote:So my steering has always been very loose but the last few days Ive been comming to a stop an the van will make like im on ice an do a front end fish tale move...any ideas what this is??
by momof4 [OP] » May 27th 2010, 8:52pm
by castle_Rock » May 27th 2010, 8:52pm
by momof4 [OP] » May 27th 2010, 8:55pm
by astroturf » May 27th 2010, 9:04pm
castle_Rock wrote:same post... same person... https://www.astrosafari.com/viewtopic.php?f=9&t=7399
by castle_Rock » May 27th 2010, 9:40pm
by astroturf » May 27th 2010, 9:49pm
by castle_Rock » May 27th 2010, 9:53pm
astroturf wrote:Castle, You know of a good shop the OP could take it to? thanks. Jim
by astroturf » May 27th 2010, 10:02pm
by castle_Rock » May 27th 2010, 10:06pm
by Astroplane » May 28th 2010, 10:35am
momof4 wrote:MAN I LOVE THIS WEB SITE tho!
castle_Rock wrote:mainly the steering linkage needs to be corrected - as well as my pass. side ball joint replaced, since I had the drivers side replaced, they're not even.
It is currently March 3rd 2021, 9:08pm
Steering Forum |
Moderator: chevy57bert |
Previous topic Next topic |
Sponsors |
