by Year1chevy [OP] » November 4th 2015, 2:35am
by Corsemoto » November 4th 2015, 2:53am
corsemoto wrote:The new Gates 365509 power steering cooler return line kit, a whopping $18 from Amazon.
The cooler mounts under the bottom radiator shroud and bumper cover. Before removing the return hose at pump, I removed one of the crimp connectors on the cooler hose and separated to try and drain as much fluid as possible.
Cooler line exits the steering gear.
After cooling, the line returns to power steering pump at the blue spring clamp.
Old cooler line and new cooler line - should be easy enough to rebuild the old cooler line for a spare by removing the crimps and using new power steering hose with fuel-injection hose clamps. Considering the new Gates return line is only $18, it may not even be worth messing with.
I added a p/s filter when I replace the pump and lines. Filled with fresh p/s fluid and bleeding was a bit difficult until I went back and read that should prime the Hydroboost system by starting van and pumping brake pedal 10-15 times, then bleeding p/s system became much more effective
by Year1chevy [OP] » November 4th 2015, 2:56am
by Coaster » November 4th 2015, 3:00am
by Corsemoto » November 4th 2015, 3:09am
by Year1chevy [OP] » November 4th 2015, 3:18am
by Silver99 » June 4th 2017, 8:33pm
by Coaster » June 4th 2017, 9:11pm
by Silver99 » June 4th 2017, 10:05pm
by dramey » June 5th 2017, 12:08am
by Silver99 » June 5th 2017, 4:25am
by 97cargocrawler » June 5th 2017, 4:48pm
by Silver99 » June 7th 2017, 9:48pm
by Mmusicman » June 7th 2017, 10:39pm
by Leeann_93 » June 8th 2017, 12:10am
by chevymaher » June 8th 2017, 1:56am
by AstroWill » June 8th 2017, 2:23am
It is currently April 13th 2021, 3:23am
Steering Forum |
Moderator: chevy57bert |
Previous topic Next topic |
Sponsors |
