2000 Safari wheels what else will they fit?
Postby plebanski [OP] » January 20th 2011, 9:08am
I bought new rims and tires for my 2000 Safari and need to sell stock rims w/tires. Had two close matches does anyone know about bolt patterns/year model? Told they fit Astros? Does anyone know if they fit any other GMC/Chevy?
plebanski
Years of Membership: plebanski has been a member for 10 full yearsplebanski has been a member for 10 full yearsplebanski has been a member for 10 full yearsplebanski has been a member for 10 full yearsplebanski has been a member for 10 full yearsplebanski has been a member for 10 full yearsplebanski has been a member for 10 full yearsplebanski has been a member for 10 full yearsplebanski has been a member for 10 full yearsplebanski has been a member for 10 full years
  • Will 9 wide wheels fit?
    by GutchDuts » December 12th 2020, 9:28pm in Wheels/Tires
    December 16th 2020, 4:08am
  • Will 03 S 10 alloy rims fit on my 02 Safari
    by YORKSTER02 » February 6th 2021, 3:05am in Wheels/Tires
    Last post by astroracer View the latest post
    February 6th 2021, 11:14pm
    89
    April 13th 2021, 12:09pm
Re: 2000 Safari wheels what else will they fit?
Postby Phantom » January 20th 2011, 1:35pm
Safari and Astro are basically the same vehicle , there is a variety of GM vehicles that have same bolt pattern which I think is 5 in , if you google you will find out which ones , as I believe the C , K 1/2 ton , full size impala , etc will fit same size wheel
Phantom
Firing on 7 Cylinders (L4)
Postby chevymaher » January 20th 2011, 1:53pm
Phantom wrote:Safari and Astro are basically the same vehicle , there is a variety of GM vehicles that have same bolt pattern which I think is 5 in , if you google you will find out which ones , as I believe the C , K 1/2 ton , full size impala , etc will fit same size wheel
You are correct on these.They also the same as other big body GM platforms Catalina bonneville Riviera.Equivilent to big impala sized GM cars.Although I not sure about the caddies I never swapped them out to know for sure.
Topics: 91
Postby Leeann_93 » January 20th 2011, 11:15pm
They're 5 x 5. I'm pretty sure the full-sized trucks are the same.
I do know Blazers/Jimmys/Bravadas are not 5 x 5; they're 5 x 4.75 so they don't fit.
Postby CaptainMorgan » January 21st 2011, 1:08am
I'm doing the same thing this weekend replacing my wheels and tires....
Are theses worth trying to sell online? Or should I just let the tire shop dispose of everything? What are they worth?
CaptainMorgan
Years of Membership: CaptainMorgan has been a member for 10 full yearsCaptainMorgan has been a member for 10 full yearsCaptainMorgan has been a member for 10 full yearsCaptainMorgan has been a member for 10 full yearsCaptainMorgan has been a member for 10 full yearsCaptainMorgan has been a member for 10 full yearsCaptainMorgan has been a member for 10 full yearsCaptainMorgan has been a member for 10 full yearsCaptainMorgan has been a member for 10 full yearsCaptainMorgan has been a member for 10 full years
Extra Info: RWD
Postby fast68 » January 22nd 2011, 1:07am
all the old wagons and some of the big cars
and all the full size trucks and vans since 71 when they went to 5 lug
1/2" wheel studs= 5 on 5" pattern same as these vans
billions of models of gm vehicles same pattern
not mid size and smaller or s series trucks though
not monte carlos not grand prix not cutlasses not s10s not camaros or firebirds or caprice classics and alot of the other modelds similar size etc unless they had towing package or 9C1 or 9C6 package
fast68
Years of Membership: fast68 has been a member for 12 full yearsfast68 has been a member for 12 full yearsfast68 has been a member for 12 full yearsfast68 has been a member for 12 full yearsfast68 has been a member for 12 full yearsfast68 has been a member for 12 full yearsfast68 has been a member for 12 full yearsfast68 has been a member for 12 full yearsfast68 has been a member for 12 full yearsfast68 has been a member for 12 full yearsfast68 has been a member for 12 full yearsfast68 has been a member for 12 full years
Topics: 12
Alias (AKA): fast
Extra Info: 4.3L Z EXT RWD
Postby chevymaher » January 23rd 2011, 9:17pm
OTHER VEHICLES WITH 85-02 ASTRO BOLT PATTERN
*note - Offset and hub center will need to be verified as it varys by year and model
71-96 Buick SeSabre
77-78 Buick Riviera
71-96 Buick Roadmaster
68-94 Cadillac Brougham/Calias
68-88 Cadillac DeVille
77-79 Cadillac Seville
71-76 Chevy Belair/Biscayne
71-96 Chevy Caprice (HD)
94-96 Chevy Impala SS
88-98 Chevy/GMC 1/2 ton 2WD trucks
94-99 Chevy Suburban 2WD
95-99 Chevy Tahoe/Yukon 2WD
98-02 Chevy Savanna/Express vans
73-78 Ford Galaxie/Futura
99-01 Jeep Grand Cherokee (wrong offset)
73-77 Mercury Cougar XR
OTHER VEHICLES WITH 03-05 ASTRO BOLT PATTERN
03-up Chevy Savana/Express vans
88-up Chevy 1500 4X4 (including Tahoe, suburban)
99-up Chevy Silverado/sierra 2WD
79-98 Toyota 4X4's
87-93 Mazda B-Series
74-92 Jeep Wagoneer
Topics: 91
Postby plebanski [OP] » January 28th 2011, 9:18am
Thanks for the cross matches/sizing etc. Turns out I sold them to someone with a 2000 astro so it looks like they stay in the family.
plebanski
Postby justsomeguy » January 28th 2011, 6:52pm
Awesome information! I was just about to ask this. At the risk of hijacking this thread, I have a question relating to the 2003+ Astro/Safari:
Just to confirm, an early 2000's Chevy Silverado set of 16" 6 lug chrome wheels should fit, right? (but must be from a 2wd)? I found a guy on craigslist who has a shop a couple of hours away. He says he has a mint set of these SIlverado rims in chrome, with center caps from Georgia, so never seen snow or salt. I'm assuming they are (and must be from) a 2wd truck. If so, they should fit my 2wd 2005 Astro, right? They look identical to the 16 steel wheels have now, only mine are painted and these are chromed. I want these chrome wheels for my 3 season tires. I bit the bullet and bought winter tires and put them on my stock painted steel wheels.
I was going to go there tomorrow, weather permitting. Thought it would be good to ask this first before driving over 2 hours each way. I may not be able to go in my Astro, so test-fitting may not be possible. We might go in another vehicle.
Here's the wheel(s) that guy has, and below, my van:
Early 2000's Chevy Silverado wheel, supposedly 16" 2wd
My 2005 Astro with 16" 6 bolt painted steel wheels
2005 Astro RWD, Base model passenger, ex-cop van, rust free, cadet blue, X Code, Front A/C
Compustar Alarm/Starter, XM Sat. Bluetooth, TransCooler, blackout grille, orange turn signals, pop-open barn door windows, 4 note Cadillac horn. Otherwise stock.
justsomeguy
Years of Membership: justsomeguy has been a member for 10 full yearsjustsomeguy has been a member for 10 full yearsjustsomeguy has been a member for 10 full yearsjustsomeguy has been a member for 10 full yearsjustsomeguy has been a member for 10 full yearsjustsomeguy has been a member for 10 full yearsjustsomeguy has been a member for 10 full yearsjustsomeguy has been a member for 10 full yearsjustsomeguy has been a member for 10 full yearsjustsomeguy has been a member for 10 full years
Topics: 45
Extra Info: Base 4.3 V6 RWD
Return to Wheels/Tires
It is currently April 13th 2021, 12:09pm
Wheels/Tires Forum
Attached by: chevymaher
in Wheels/Tires
Time: 11:52pm
Attached by: ssbf1
ssbf1
in Wheels/Tires
Time: 7:24pm
Macwicker
in Wheels/Tires
Date: Mar 20 '21
Time: 5:54pm
Jimmy111
in Wheels/Tires
Date: Mar 18 '21
Time: 12:10am
Bikley
in Wheels/Tires
Date: Mar 15 '21
Time: 3:58pm
Users browsing this forum: Yandex [Bot] and 3 guests
