Staggered Fitment
Staggered Fitment
Postby meetthespeakers [OP] » July 30th 2012, 8:38pm
Well looks like I am going to do a few more mods to the vans since it's been a while. I ordered the tires up and getting ready to order up the wheels. I am kinda doing a hotrod them, 17x8 front, 18x9 rears. Front tires I will reuse which are 235/55/17's. Now I didn't want to have the rear side wall height smaller than the front, so I decided to go with a 255/55/18. Any thoughts on this combo? Figured as a side benefit I would turn less rpms on the highway...
Section Width: 10.03 in
Rim Diameter: 18 in
Rim Width Range: 7 - 9 in
Overall Diameter: 29.04 in
Sidewall Height: 5.52 in
Radius: 14.52 in
Circumference: 91.23 in
Revs per Mile: 716.2
Speedometer1: 56.1 mph
The rim I am looking at has a 0 offset for the 9" rear wheel. So looks like it would push it out 1/2" outward than my current setup. So I don't see this being a problem. To think I have had Astro's since 1986, probably been through about 10 sets, but never tried the staggered in height setup. Thoughts?
1998 Astro, 1993 Astro, 1976 Austin Mini Clubman Estate, 1975 Trabant, 1961 Morris Minor
meetthespeakers
Years of Membership: meetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full yearsmeetthespeakers has been a member for 12 full years
Topics: 69
Extra Info: Bagged
Re: Staggered Fitment
Postby meetthespeakers [OP] » July 30th 2012, 8:40pm
Here is the wheels I am looking at:
meetthespeakers
Topics: 69
Extra Info: Bagged
Postby meetthespeakers [OP] » August 2nd 2012, 2:42pm
Well, tires came in last night, they look pretty meaty. Did a test fitment on the rear, def going to fill up the wheel well a healthy amount. I may not lower the rear any more, so it will def have a rake to it. Will post pictures when the new wheels arrive. I decided to change wheels, as much as I wanted to get Coys/Rev Classics, Coys being expensive, and Rev's being the right price, but not having the best fitment on the rear I am gonna go with Show Wheels. The offset looks like it will tuck a hair more on the back with a deep dish. Logo on wheel is love it or hate it, atleast in black it is not as noticeable as in the other color choices.
meetthespeakers
Topics: 69
Extra Info: Bagged
Postby meetthespeakers [OP] » August 6th 2012, 8:57pm
Alright, well finally placed the order, did a fast one at the end. Ended up going with US MAGS u106 Wheels 17x8" Front, and 18x9" Rear. The price and the fact that the entire wheel is clear coated, unlike Boss 338 wheels made me decide to go with them. Plus the backspacing I felt a little safer with. Fronts have a 4.5" BS, and Rears have a 5.25" BS. So that should only kick the wheel out .25/50". I went with a black center, anyway this is what they will look like, hope to have them by the end of the week. Will snap some pics when I can:
meetthespeakers
Topics: 69
Extra Info: Bagged
Postby ProStreet_LS1 » August 7th 2012, 7:32pm
Very cool
That is a lot of meat for the rears. You could do like a mini tub. You may not have to go wider, possibly just square up the stock rear tubs, get rid of roundness. But a little taller tub could be helpful.
1985 Pro Street Chevy Astro: parted, scrapped & upgraded to
1998 Pro Street Chevy Astro: Tubbed w/ 33x22 rear tires, 350 hp aluminum LS1 V8
PRO STREET 4 LIFE, GEARHEAD 4 LIFE
ProStreet_LS1
Years of Membership: ProStreet_LS1 has been a member for 10 full yearsProStreet_LS1 has been a member for 10 full yearsProStreet_LS1 has been a member for 10 full yearsProStreet_LS1 has been a member for 10 full yearsProStreet_LS1 has been a member for 10 full yearsProStreet_LS1 has been a member for 10 full yearsProStreet_LS1 has been a member for 10 full yearsProStreet_LS1 has been a member for 10 full yearsProStreet_LS1 has been a member for 10 full yearsProStreet_LS1 has been a member for 10 full years
Topics: 54
Extra Info: LS1 V8 Pro Street
Postby meetthespeakers [OP] » August 7th 2012, 7:47pm
You think I am going to have a problem with 255's? I know at one point in it's life I had 245's that rubbed the outer lip, I am hoping these will tuck a hair more. It's gonna be close, haven't people run 275's with 20x10's on here stock?
meetthespeakers
Topics: 69
Extra Info: Bagged
Postby ProStreet_LS1 » August 10th 2012, 6:37pm
Sorry, I have no idea what will fit. I do know how to modify the wheel wells. I was just saying, if you want to lower it or do some hauling, may have to modify the wheel well.
A baseball bat can be used to curl the lip up for clearence.
ProStreet_LS1
Topics: 54
Postby Bis » March 8th 2015, 2:49am
Was looking for an update on this thread as I would one day love to get a staggered setup, with 19" minimum. 20" preferably with stock suspension, etc.
Any recommendations or warnings would be appreciated. I have successfully fit 20" (0 offset) wheels in before.
Ideally would like to fit 20" X 8" up front and 20" X 9.5" rear, though not sure if that will even look right.
I am also on a 2003 model, not a 2001, so I am unsure if hub/axle dimensions have changed at all.
✔ Recovering 3-Time ex-Aerostar owner since 1996.
✔ RC Hobbyist and Dance music nut.
✔ Geeky Astroholic.
ツ Glad to be of help! ツ
Bis
Years of Membership: Bis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full yearsBis has been a member for 9 full years
Topics: 30
Alias (AKA): Bis
Extra Info: LS 4.3L V6 RWD
Postby meetthespeakers [OP] » March 9th 2015, 2:17pm
20x8 and 20x9.5 should be no problem, obviously with the right offset. I ran that same width except in 18's. They were the ridler 695's I believe in 18x8, and 18x9.5. They fit perfect, I ran 235 up front and a skinny 255 on the rear. The rear just cleared for some reason, like I said before I know people have run wider tires with no problem, and on mine I had a 3" drop in the rear. I am back to 15x8's now, but in spring/summer I may be looking at moving up to 20's and just keeping these as winter wheels, we will see.
meetthespeakers
Topics: 69
Extra Info: Bagged
  • Wheel/tire Fitment
    by olechka » December 31st 2013, 4:03am in Wheels/Tires
    Last post by Tcramer View the latest post
    January 4th 2014, 8:09pm
    11Replies
    145Replies
    December 1st 2020, 3:31pm
  • Tire fitment for new rims?
    Attachment(s) by Rein » January 22nd 2020, 9:03pm in Wheels/Tires
    Last post by Rein View the latest post
    January 27th 2020, 10:09am
Return to Wheels/Tires
It is currently December 1st 2020, 3:31pm
Wheels/Tires Forum
greenvan02
in Wheels/Tires
Date: Nov 28 '20
Time: 10:27pm
Lowcountry
in Wheels/Tires
Date: Nov 10 '20
Time: 11:59pm
in Wheels/Tires
Date: Oct 15 '20
Time: 10:59pm
Sailing_Faith
in Wheels/Tires
Date: Sep 22 '20
Time: 8:26pm
SheldonYoung
in Wheels/Tires
Comments: 22
Date: Sep 05 '20
Time: 9:17pm
