Size & Brand on Stock
Postby catbones [OP] » February 17th 2014, 9:04pm
Hi guys,
So since I'm keeping the Astro, I'm also going to replace the tires on it in a few weeks. I'm doing my research now for the better deal. Now as you all know, I also tow a 3000 - 3500lbs trailer behind me most of the summer. My Astro is also pretty basic in terms of lifts, none that is. I do think that the PO did something because compare to other ones around here, it sits a little higher and my right front tire rubs off on tight turns. Maybe he just put bigger tires.
However, my newbie question would be, what's the perfect size of tire and brand I can look at without doing any type of lift on here. Unless, at minimum I can do a lift and get more height for the new tires.
catbones
Years of Membership: catbones has been a member for 7 full yearscatbones has been a member for 7 full yearscatbones has been a member for 7 full yearscatbones has been a member for 7 full yearscatbones has been a member for 7 full yearscatbones has been a member for 7 full yearscatbones has been a member for 7 full years
Topics: 83
Alias (AKA): catbones
Extra Info: Base 4.3L V6 AWD
  • gitt'n harder to find stock size boots
    by SoFar,EH » January 12th 2021, 4:01am in Wheels/Tires
    Last post by SoFar,EH View the latest post
    January 12th 2021, 9:43pm
  • what brand tires do you prefer and why
    by markmitch » December 29th 2020, 9:00pm in Wheels/Tires
    December 30th 2020, 3:26pm
    9
    15
    March 7th 2021, 6:16pm
Re: Size & Brand on Stock
Postby 97cargocrawler » February 17th 2014, 10:37pm
I've always been a HUGE fan of BFG A/T's. No matter the size they can make anything look like a truck and the handling in my opinion is excellent.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby Allmntrider » February 17th 2014, 10:51pm
2nd that on the bfg's. The sidewalls usually dry rot before the tread wears out. Coopers if you want a American made and owned tire.
Allmntrider
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: Allmntrider has been a member for 7 full yearsAllmntrider has been a member for 7 full yearsAllmntrider has been a member for 7 full yearsAllmntrider has been a member for 7 full yearsAllmntrider has been a member for 7 full yearsAllmntrider has been a member for 7 full yearsAllmntrider has been a member for 7 full years
Images: 4
Alias (AKA): Explorer
Extra Info: Lifted awd 3.73 g80
Postby WoodButcher » February 18th 2014, 12:21am
The stock size should be on the door sticker. What ever tire you choose be sure to get an "LT" (light truck) generally speaking they are inflated to 45 or 50 psi, have thicker, more plies in the sidewall that will give you stability when towing or loaded.
WoodButcher
Firing on 5 Cylinders (L6)
Topics: 30
Images: 514
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby chevymaher » February 18th 2014, 12:42am
WoodButcher wrote:The stock size should be on the door sticker. What ever tire you choose be sure to get an "LT" (light truck) generally speaking they are inflated to 45 or 50 psi, have thicker, more plies in the sidewall that will give you stability when towing or loaded.
You left out the good part. I gets rid of the driving on butter feeling in the corners.
Postby catbones [OP] » February 18th 2014, 12:50am
97cargocrawler wrote:I've always been a HUGE fan of BFG A/T's. No matter the size they can make anything look like a truck and the handling in my opinion is excellent.
Like these http://www.tirerack.com/tires/tires.jsp ... n+T%2FA+KO
catbones
Topics: 83
Postby 97cargocrawler » February 18th 2014, 1:21am
Yup! Been driving in trucks with those for over 30 years. They are superb.
97cargocrawler
Topics: 42
Postby catbones [OP] » February 18th 2014, 1:34am
They look sweet I bet the ride is awesome too
catbones
Topics: 83
Postby catbones [OP] » February 18th 2014, 1:35am
Any good place online for buying tires?
catbones
Topics: 83
Postby 97cargocrawler » February 18th 2014, 2:54am
I bought my last set on Amazon but that's simply because I can no longer deal with the rejects at 4wheelparts. I think Costco and Sears typically stock these in normal sizes if you have those stores near you. The BFG A/T's are a pretty common truck tire so they are usually not hard to find locally. Often places have deals on these tires.
97cargocrawler
Topics: 42
Postby catbones [OP] » February 18th 2014, 2:59am
97cargocrawler wrote:I bought my last set on Amazon but that's simply because I can no longer deal with the rejects at 4wheelparts. I think Costco and Sears typically stock these in normal sizes if you have those stores near you. The BFG A/T's are a pretty common truck tire so they are usually not hard to find locally. Often places have deals on these tires.
Thanks for the info :) btw awesome stuff what you did with your van !
catbones
Topics: 83
Postby markmitch » February 18th 2014, 3:42am
another excellent tire is hercules I had there terra tracs on a truck and on my van I have hercules HP 4000 265/60R15 on the back and 245/70R15 on the front Hercules also has a tire called trail diggers on a big lifted 4x4 K5 blazer and those would climb anything and sling some serious mud. Very good tire brand made in the USA by cooper.
Firing on 8 Cylinders (L6)
Topics: 626
Images: 21
Extra Info: RS V8 AWD
Postby ronaldperu » February 18th 2014, 4:57am
go to onlinetires.com, i always get there the best prices
ronaldperu
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: ronaldperu has been a member for 7 full yearsronaldperu has been a member for 7 full yearsronaldperu has been a member for 7 full yearsronaldperu has been a member for 7 full yearsronaldperu has been a member for 7 full yearsronaldperu has been a member for 7 full yearsronaldperu has been a member for 7 full years
Topics: 10
Images: 43
Alias (AKA): ROJO
Van Model Year: 1996
Extra Info: ls
Postby catbones [OP] » April 22nd 2014, 7:12pm
just returning to this, I'm thinking of putting th A/T tires on.. but I'm wondering 1.) what size can I fit under a normal height (no lift) ... I think its 16 the norm, 2.) am I also going to have to replace the rips as well with these A/T tires?
catbones
Topics: 83
Postby SilverBullet1997 » April 22nd 2014, 9:01pm
Your year is a 16" Rim, I believe your stock size tire is a 215/70R16, I ran the BFG A/T T/A KO's in the stock size on my van with the stock rims, which were LT215/75r15(my van is a 97). You do not need to change your rims to run a stock sized tire.
I recommend Discount Tire if you have not already checked them out, they are really one of the best companies out there in my opinion, they have great customer service, 1000's of locals.
BTW: Now I run LT31x1050r15 BFG's A/T's.....
I just crunched the numbers at Discount Tire(in my local zipcode) the tires in your stock size 215/70r16 are 187$, mine in the stock size were 137$.... Quite a difference in price.... Probably because it is not a 'common size', I would recommend calling discount tire and talking to one of their tech's and seeing if there is a 'common size' tire that would fit without rubbing.
R.I.P.-1997 Astro AWD SilverBullet I 4-9-1997 to 2-17-2015 - Cause of death: Rear-ended
R.I.P.-1999 Astro AWD SilverBullet II 1-4-1999 - July-2016 - Cause of death: Roadrash passenger side
Current: 1999 Astro AWD GreenBullet I - Purchased 02/2018
SilverBullet1997
Firing on 6 Cylinders (L2)
Years of Membership: SilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full years
Topics: 54
Images: 247
Alias (AKA): Silver or Bullet or SB
Extra Info: 7in Lift AWD Z71
Postby Lumpy » April 22nd 2014, 9:45pm
SilverBullet1997 wrote:
...I recommend Discount Tire...
I do as well.
We have a total of 36 tires on various rolling items from garden carts to 1 ton trucks to trailers. Every one of them has tires bought from and installed by DiscountTire. We always buy the road hazard warranty on cars, trucks and trailers. They only charge us for tires/tubes (no installation) on garden carts and riding lawnmowers.
Rotate, balance any time you want. Repair or replace under warranty when needed. Hot lookin' Scottsdale moms in their luxury Beemers and HumVees pulling in to get their tire pressure checked. Young, strong boys hustle to get your tires on and off. They even have free bottled water in the lobby. All that and if you CAN beat the price anywhere, it's only by a dollar or two for the entire car. And they'll usually match or beat that if you ask.
Postby SilverBullet1997 » April 22nd 2014, 9:48pm
.....Young, strong boys hustle to get your tires on and off.....
:whistle:
Lumpy wrote: All that and if you CAN beat the price anywhere, it's only by a dollar or two for the entire car. And they'll usually match or beat that if you ask.
Yay! That too...
SilverBullet1997
Topics: 54
Images: 247
Postby Tegnus » April 22nd 2014, 10:28pm
On the other hand I think BFG A/T's are outdated, they are still being bought because people tend to use old technology and trust it, but it's matter of time until they realize there are far superior tires on market...
If that would be case in technology we would still be using Nokia and Blackberry not Smartphones like iPhones with touchscreens etc.
2004 Astro AWD (Astrid), 3" Lift, BFG All-Terrain T/A KO2 LT225/75R16, Tru-Cool LPD-4490 Trans cooler, ARB Awning 2500 (ARB4401A)
Follow us on Facebook and Instagram | Check out the build of our 2004 Chevy Astro AWD "Astrid"
Tegnus
Years of Membership: Tegnus has been a member for 7 full yearsTegnus has been a member for 7 full yearsTegnus has been a member for 7 full yearsTegnus has been a member for 7 full yearsTegnus has been a member for 7 full yearsTegnus has been a member for 7 full yearsTegnus has been a member for 7 full years
Topics: 38
Images: 6
Postby Lumpy » April 22nd 2014, 10:32pm
Tegnus wrote:On the other hand I think BFG A/T's are outdated, they are still being bought because people tend to use old technology and trust it, but it's matter of time until they realize there are far superior tires on market...
I filled my BFG A/Ts with DexCool. Made a world of difference both on and off road.
Postby SilverBullet1997 » April 22nd 2014, 10:41pm
I am sure it did, on road you turned into a milk shake, off road you go anywhere!
SilverBullet1997
Topics: 54
Images: 247
Return to Wheels/Tires
It is currently March 7th 2021, 6:16pm
Wheels/Tires Forum
Bikley
in Wheels/Tires
Date: Feb 27 '21
Time: 7:01am
in Wheels/Tires
Comments: 13
Date: Feb 17 '21
Time: 3:35am
YORKSTER02
in Wheels/Tires
Date: Feb 06 '21
Time: 3:57am
Lowcountry
in Wheels/Tires
Date: Jan 11 '21
Time: 5:58am
in Wheels/Tires
Date: Jan 08 '21
Time: 1:54am
