How To: 31x1050r15
How To: 31x1050r15
Postby SilverBullet1997 [OP] » March 6th 2014, 6:32pm
How to go from a stock 215/75r15 tire(left) to a 31x1050r15(right)
To get it to fit on this OLV lifted van:
You need these.
:rofl:
You get this:
Obviously, there is more to this than just that, We used a jigsaw to cut the bumper, and some of the cladding away, but I did have to take a sledgehammer to a little bit of the inner fender well, and a metal cut off blade, you have to relief cut and bend the tack weld seam over so it is not running parallel with the van.
Jasen: Cutting the bumper
Cutting the cladding
Removed cladding bracket, preparing to cut tack weld seam
See, I do, do some of the work on my van, it is not all Jasen... It is just hard to take pics and do the work at the same time...
Relief cuts in seam, bent over.
Relief cuts in seam, some of bottom tab cut off.
Using Jasen's girlfriends* :lol: hammer to bend the tabs in. (*Not really Jasen's girlfriends, as Jasen is happily married, just had to give him some stink about having such a small hammer)
Those cuts on the seam worked well, but there was still not enough room for full turn without rub yet, so I had to take a sledgehammer to the inner part of the fenders to make it fully work. Was not able to take anymore pics as we were on a time crunch at that point as it was already past 9pm and I have neighbors who I am sure do not want to hear the loud banging of a sledgehammer on sheet metal past 9. Plus had to remove some more of that tab(where you see the screw hole for the old bracket)
Finished?....... NEVER!
More pictures to come later:
R.I.P.-1997 Astro AWD SilverBullet I 4-9-1997 to 2-17-2015 - Cause of death: Rear-ended
R.I.P.-1999 Astro AWD SilverBullet II 1-4-1999 - July-2016 - Cause of death: Roadrash passenger side
Current: 1999 Astro AWD GreenBullet I - Purchased 02/2018
SilverBullet1997
Firing on 6 Cylinders (L2)
Years of Membership: SilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full years
Topics: 54
Images: 247
Alias (AKA): Silver or Bullet or SB
Extra Info: 7in Lift AWD Z71
Re: How To: 31x1050r15
Postby Jasen » March 7th 2014, 2:40am
I'll let you know that hammer is 1 full pound of 'merian STEEL, made by Stanley tools, a true 'merican company.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby Jasen » March 12th 2014, 2:03am
Before
After
The stock mid grade wheels and BFG KO's makes mine look better too.
200k
Ultra gauge
Topics: 260
Images: 101
Postby SilverBullet1997 [OP] » March 17th 2014, 8:50pm
Had a little bit of rubbing on the drivers side up front, so banged that back a little bit more with a BFH.
(You can see where the primer got rubbed off a bit. Banged it back, re-primed then installed items below.
Picked up some cheap plastic mud flaps from O'reillys(LAPS) for 6$
Also picked up some screws(from Lowe's Hardware Store - 5$) to install the modified mud flaps, and re-secure down the mud skirts on the inside because the lower holes no longer matched the holes in the frames.
Then Jasen and I cut them down to make them fit the curve and fastened them in to keep the debris from flying up in to the door well areas.
As you can note in the picture above, I get a little bit of inner frame rub on the tires(nice shiney spot) on the passenger side.
SilverBullet1997
Topics: 54
Images: 247
Postby plumbedastro » March 18th 2014, 12:38am
Nice
plumbedastro
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: plumbedastro has been a member for 6 full yearsplumbedastro has been a member for 6 full yearsplumbedastro has been a member for 6 full yearsplumbedastro has been a member for 6 full yearsplumbedastro has been a member for 6 full yearsplumbedastro has been a member for 6 full years
Images: 15
Extra Info: LS 4.3 V6 rwd
Postby survival bill » April 30th 2014, 11:55pm
I wonder what new rubber you could get on a stock truck with them body mods?
survival bill
Years of Membership: survival bill has been a member for 6 full yearssurvival bill has been a member for 6 full yearssurvival bill has been a member for 6 full yearssurvival bill has been a member for 6 full yearssurvival bill has been a member for 6 full yearssurvival bill has been a member for 6 full years
Topics: 31
Alias (AKA): Survival Bill
Extra Info: AWD 4.3L V6
Postby WoodButcher » May 1st 2014, 3:41am
My '97 2wd? LT 235/75 x 15 on the front and 31 x 10.50 with tall springs on the back.
@SB, you should feel privileged to use that hammer, when you grow up and get old enough maybe we'll let you buy one...
If I could justify the cost I'd get one of those 10oz. magnesiums.
WoodButcher
Firing on 5 Cylinders (L6)
Topics: 30
Images: 513
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby SilverBullet1997 [OP] » May 1st 2014, 3:52am
WoodButcher wrote:My '97 2wd? LT 235/75 x 15 on the front and 31 x 10.50 with tall springs on the back.
I have gone through a couple of these, with waffle print head.
and a couple of these
Doing concrete construction kills hammers....(I don't do concrete anymore)
Now I carry a hammer similar to this in my van at all times...
SilverBullet1997
Topics: 54
Images: 247
Postby thegreenmachine » May 1st 2014, 5:13am
I have a couple of those.....
"that looks legit"
95 AWD Safari money pit
thegreenmachine
Years of Membership: thegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full years
Topics: 62
Alias (AKA): Shane a lane
Postby SilverBullet1997 [OP] » May 1st 2014, 6:23am
That looks legit :rockon:
SilverBullet1997
Topics: 54
Images: 247
Postby [email protected] » May 3rd 2014, 8:04am
If I had a hammer for every hammer I broke, I'd have one hammer. :rofl:
(Get it, because it keeps replacing the last one?) :wave:
'06 Impala 3.5(FF)
'91 Civic Hatch 4-sp - Sold
'97 Astro AWD - Cracked Head
'80 C10: "Arianne" -SOLD
[email protected]
Years of Membership: Aaron@OER has been a member for 6 full yearsAaron@OER has been a member for 6 full yearsAaron@OER has been a member for 6 full yearsAaron@OER has been a member for 6 full yearsAaron@OER has been a member for 6 full yearsAaron@OER has been a member for 6 full years
Topics: 7
Images: 6
Extra Info: AWD 3.73
Postby MmusicmanMmusicman is online! » May 3rd 2014, 1:03pm
[email protected] wrote:If I had a hammer for every hammer I broke, I'd have one hammer. :rofl:
Awesome quote!!! :rockon:
Firing on 6 Cylinders (L5)
Topics: 73
Images: 49
Postby Lumpy » May 3rd 2014, 1:23pm
My hammer was handed down to me from my great-great grandfather. It's had three heads and four handles and it's still hammering good as new.
Postby [email protected] » May 3rd 2014, 6:50pm
Lumpy wrote:My hammer was handed down to me from my great-great grandfather. It's had three heads and four handles and it's still hammering good as new.
3 heads, and 4 handles... I don't see where the original hammer is :rofl: :D
'06 Impala 3.5(FF)
[email protected]
Topics: 7
Images: 6
Return to Wheels/Tires
It is currently November 30th 2020, 11:50pm
Wheels/Tires Forum
greenvan02
in Wheels/Tires
Date: Nov 28 '20
Time: 10:27pm
Lowcountry
in Wheels/Tires
Date: Nov 10 '20
Time: 11:59pm
in Wheels/Tires
Date: Oct 15 '20
Time: 10:59pm
Sailing_Faith
in Wheels/Tires
Date: Sep 22 '20
Time: 8:26pm
SheldonYoung
in Wheels/Tires
Comments: 22
Date: Sep 05 '20
Time: 9:17pm
