Wheel/Rim recommendations?
Postby Canyonero [OP] » August 20th 2014, 2:54am
Tonight I got my 4 new Cooper LT235/75/15's in….. For now they'll have to go on my stock 2002 LT alloy rims which all have some pretty bad salt damage. I'm looking into new rims, but have never bought rims before, only used and kept what was stock on my vehicles.
Any recommendations as to a rim suited to my AWD with 235/75/15" will help.
Do I go with the same size rim, or are there better fits to my new tire size?
Should I be looking at chrome, alloy or something more resistant to salt and dirt roads?
I'm not up on brands of rims, and would like to make this simpler than it was deciding on tires...
Thanks for any recommendations/tips :ty:
Canyonero
Years of Membership: Canyonero has been a member for 6 full yearsCanyonero has been a member for 6 full yearsCanyonero has been a member for 6 full yearsCanyonero has been a member for 6 full yearsCanyonero has been a member for 6 full yearsCanyonero has been a member for 6 full years
Topics: 30
Van Model Year: 2002
Extra Info: LT 4.3 V6 AWD
  • Rim and tire question
    by Dottie10 » January 11th 2021, 2:53am in Wheels/Tires
    Last post by pmou View the latest post
    February 18th 2021, 5:55pm
  • Rim/Tire question.
    by Lecky313 » January 25th 2021, 11:22pm in Wheels/Tires
    Last post by Lecky313 View the latest post
    January 28th 2021, 5:03pm
    7
    12
    February 27th 2021, 10:33pm
Re: Wheel/Rim recommendations?
Postby Canyonero [OP] » August 20th 2014, 3:16am
This is what I'm leaning towards… if they're low maintenance enough… I figure a painted wheel is easy to touch up anytime… Alloys are a mess when salt gets through the clear coat….
How are these GM steel wheels? I just need to find 5 lug 15" GM rims ? Or are there other dimensions I need to be aware of?
I'm unsure of which Offset…. which Bore diameter and the best width. I believe stock was 6.5" .. 7" seems right for 235's...
Canyonero
Topics: 30
Postby Canyonero [OP] » August 20th 2014, 3:17am
Here's my van as it sits today with the old tires..
Canyonero
Topics: 30
Postby chevy57bert » August 20th 2014, 8:39am
That rear axle, to far forwards??
chevy57bert
Section Moderator
Section Moderator
Firing on 7 Cylinders (L3)
Years of Membership: chevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full years
Topics: 69
Images: 68
Alias (AKA): Bertjuh
Extra Info: Ext 4.3L rwd
Postby Canyonero [OP] » August 20th 2014, 4:33pm
I'm not sure…. It's a 2" shackle lift….. What would cause it to be forward ?
Although from a quick image search , it seems they all look that way with a 2" shackle lift…
If it is, how would I go about correcting it? A shim , or a helper spring ?
* Just measured… I've got about 3" clearance in rear of tire and 2.5" in front of tire….
Canyonero
Topics: 30
Postby 97cargocrawler » August 20th 2014, 5:11pm
Canyonero wrote:I'm not sure…. It's a 2" shackle lift….. What would cause it to be forward ?
Yes the shackle will move the wheel slightly forward. Nothing to worry about because the wheel arcs back when the suspension flexes. Mostly it's a cosmetic concern until you install large tires. No shims or leafs will correct it. You can swap stock spring hangers from side to side to move it back a bit (or leave them in place and drill new holes), or buy adjustable spring hangers. It's nothing to be concerned with until you rub.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby SilverBullet1997 » August 20th 2014, 5:13pm
You could always spin the front leaf spring hanger around on the drivers side, I have yet to do this, but will eventually when I get around to it, most of the Astro van's the tire does sit closer to the front of the well on the drivers side, it is just easier to see this once you go bigger tires and a lift....
The front spring hanger in the rear have an off-centered hole, so if you flip it around and remount it it will be off-centered to the rear instead of the front, which would move that part of the axle back.
More pictures with measurements: http://digitalcartography.com/n0eq/astro/LeafHangers/
Pictures are from Lumpy, thanks for the detailed pictures.
Taken from topic: viewtopic.php?f=41&t=13270
R.I.P.-1997 Astro AWD SilverBullet I 4-9-1997 to 2-17-2015 - Cause of death: Rear-ended
R.I.P.-1999 Astro AWD SilverBullet II 1-4-1999 - July-2016 - Cause of death: Roadrash passenger side
Current: 1999 Astro AWD GreenBullet I - Purchased 02/2018
SilverBullet1997
Firing on 6 Cylinders (L2)
Years of Membership: SilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full years
Topics: 54
Images: 247
Alias (AKA): Silver or Bullet or SB
Extra Info: 7in Lift AWD Z71
Postby Canyonero [OP] » August 20th 2014, 5:40pm
Thanks guys… Had me worried for a bit… although I've drive 100+ miles since the lift and all is well. I don't think there's any vibration, tough to tell, if there is it's minor. But I know I'm due for 2 new U joints too.
I may get my new tires put on the OEM rims for now and pick up some Cragers when I decide what rim I like…
Canyonero
Topics: 30
Postby chevy57bert » August 20th 2014, 6:28pm
Your figure will it out Canyonero..:)
Glad we have Lumpy......
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Postby kenk » August 20th 2014, 7:27pm
chevy57bert wrote:Your figure will it out Canyonero..:)
who is Lumpy????
23217
kenk
Years of Membership: kenk has been a member for 8 full yearskenk has been a member for 8 full yearskenk has been a member for 8 full yearskenk has been a member for 8 full yearskenk has been a member for 8 full yearskenk has been a member for 8 full yearskenk has been a member for 8 full yearskenk has been a member for 8 full years
Topics: 32
Images: 5
Extra Info: SLT AWD
Postby SilverBullet1997 » August 20th 2014, 8:28pm
who is Lumpy????
This has got to be a joke.....
You have been here for 2 years....
I am sure you have seen one of lumpy's post, I think he has posted in every thread there ever was.... :shifty:
Lumpy is our resident comedian and more!
SilverBullet1997
Topics: 54
Images: 247
Postby chevy57bert » August 20th 2014, 9:09pm
Lumpy is our (P)resident comedian and more!
:rofl:
chevy57bert
Section Moderator
Section Moderator
Topics: 69
Images: 68
Postby Lumpy » August 20th 2014, 9:22pm
That's not funny. No soup for you!
Postby SilverBullet1997 » August 20th 2014, 10:11pm
But that is my favorite soup mix!!! You soup-nazi!
SilverBullet1997
Topics: 54
Images: 247
Postby Canyonero [OP] » August 20th 2014, 11:20pm
Kenk, your van looks just like mine…
What kind of rims are those ?
I like these simple Cragar 15x7 black steel rims… They look nice with center caps and stainless rings.
I'm unsure which backspacing is correct for my 235/75/15's on a 2" lift…
Canyonero
Topics: 30
Postby kenk » August 21st 2014, 1:00am
Canyonero wrote:Kenk, your van looks just like mine…
What kind of rims are those…
American raceing Baja, no clear coat, I put 225/75/16 on, no go, it's not lifted, so we tried 215/65/16, no issues, they do hang out a few inches more than stock, but I'm good with that
23217
kenk
Topics: 32
Images: 5
Extra Info: SLT AWD
Postby Canyonero [OP] » August 21st 2014, 7:45am
Those are nice….
I have my new tires and don't want to wait for rims.. so I'm using my originals… At least I can take my time and switch them later. Still need to do a new fender and hood from deer damage anyway…
Really like the look of this Astro with grill fins painted black… although the rims are too flashy for me.
Canyonero
Topics: 30
Postby kenk » August 21st 2014, 3:03pm
while I really like the flashy rims, in reality, i`m too lazy to maintain them, my Baja`s are not clear coated, I will take them off every spring and polish them
23217
kenk
Topics: 32
Images: 5
Extra Info: SLT AWD
Return to Wheels/Tires
It is currently February 27th 2021, 10:33pm
Wheels/Tires Forum
Bikley
in Wheels/Tires
Date: Today
Time: 7:01am
in Wheels/Tires
Comments: 13
Date: Feb 17 '21
Time: 3:35am
YORKSTER02
in Wheels/Tires
Date: Feb 06 '21
Time: 3:57am
Lowcountry
in Wheels/Tires
Date: Jan 11 '21
Time: 5:58am
in Wheels/Tires
Date: Jan 08 '21
Time: 1:54am
