used aluminum wheels
Postby bonjoey [OP] » April 12th 2010, 12:45am
found this on local ads, lowest seller will let it go is $80cad tires are no good.
what do you think?
05 FREESTAR (wife's van) 4.2L 200hp/260tq
99 SAFARI SL (SOLD) rwd 3.42 gov-loc
96 CIVIC SI (my work car) 1.6L vtec half a million kms
97 ASTRO AWD (my current van) trans replaced, fixed heat issue, oil cooler lines and oil pan gasket leaking
bonjoey
Years of Membership: bonjoey has been a member for 12 full yearsbonjoey has been a member for 12 full yearsbonjoey has been a member for 12 full yearsbonjoey has been a member for 12 full yearsbonjoey has been a member for 12 full yearsbonjoey has been a member for 12 full yearsbonjoey has been a member for 12 full yearsbonjoey has been a member for 12 full yearsbonjoey has been a member for 12 full yearsbonjoey has been a member for 12 full yearsbonjoey has been a member for 12 full yearsbonjoey has been a member for 12 full years
  • Used rims
    by tungtide » June 13th 2020, 5:47pm in Wheels/Tires
    Last post by stent View the latest post
    June 18th 2020, 6:23am
  • New 15" Wheels for Surfari
    by SheldonYoung » August 19th 2020, 10:59pm in Wheels/Tires
    Last post by SheldonYoung View the latest post
    August 19th 2020, 11:41pm
    7
    89
    December 1st 2020, 12:01am
Re: used aluminum wheels
Postby kocka80 » April 12th 2010, 1:27am
$80 for all four ?? buy them at least thats what I would do. even if you fund out that they`re not good afterwards the local recycleing place will give you that much , :) nothing to lose. I like those rims not too fancy but looks better then the original.
kocka80
kocka80
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: kocka80 has been a member for 12 full yearskocka80 has been a member for 12 full yearskocka80 has been a member for 12 full yearskocka80 has been a member for 12 full yearskocka80 has been a member for 12 full yearskocka80 has been a member for 12 full yearskocka80 has been a member for 12 full yearskocka80 has been a member for 12 full yearskocka80 has been a member for 12 full yearskocka80 has been a member for 12 full yearskocka80 has been a member for 12 full yearskocka80 has been a member for 12 full years
Postby astroturf » April 12th 2010, 2:47am
bonjoey wrote:found this on local ads, lowest seller will let it go is $80cad tires are no good.
what do you think?
What were they mounted on before? What is the lug pattern, offset, width, bore diameter? And last but not least, do you plan on using them on your van? Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby bonjoey [OP] » April 12th 2010, 3:15am
they were mounted on an astro, 215/75/15 tires but only 10-20% thread left. with that bolt pattern it will only fit in my safari lol
bonjoey
Postby astroturf » April 12th 2010, 3:29am
bonjoey wrote:they were mounted on an astro, 215/75/15 tires but only 10-20% thread left. with that bolt pattern it will only fit in my safari lol
Keep going, only a couple more questions to answer...
astroturf
Topics: 112
Postby bonjoey [OP] » April 12th 2010, 4:02am
not sure on bore, width and offset, i will probably check it tomorrow and see the condition of the wheels.
bonjoey
Postby astroturf » April 12th 2010, 4:10am
bonjoey wrote:not sure on bore, width and offset, i will probably check it tomorrow and see the condition of the wheels.
Those other things will affect how they will work/not work on your van. Good Luck. Jim
astroturf
Topics: 112
Postby LEVE » April 12th 2010, 4:11pm
Had I not found these...
I would have jumped on the deal.
I wanted rims on which I could mount studded tires. The tire shops charge $50 to mount/remount the tires each winter/spring when the studs have to come off. I found the wheels for $60 and they will pay for themselves in less than one year by not paying mount/remount fees.
The wrecking yards, here, are charging $26 per used steel rim. When I called the wrecking yards they only had one set.
IMHO, you've got a deal.
LEVE
Years of Membership: LEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby Mr_Bowtie » April 12th 2010, 8:31pm
Ya, thats a good deal. I paid $50 for my set of 4 aluminum wheels, but that guy just wanted them gone. Those are nice looking wheels too.....they got a nice dish to them. 8-)
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Return to Wheels/Tires
It is currently December 1st 2020, 12:01am
Wheels/Tires Forum
greenvan02
in Wheels/Tires
Date: Nov 28 '20
Time: 10:27pm
Lowcountry
in Wheels/Tires
Date: Nov 10 '20
Time: 11:59pm
MmusicmanMmusicman is online!
in Wheels/Tires
Date: Oct 15 '20
Time: 10:59pm
Sailing_Faith
in Wheels/Tires
Date: Sep 22 '20
Time: 8:26pm
SheldonYoung
in Wheels/Tires
Comments: 22
Date: Sep 05 '20
Time: 9:17pm
