by theGlasswalker [OP] » April 20th 2015, 2:42am
by AstroWill » April 20th 2015, 6:45am
Tire Chains
Notice: Use tire chains only where legal and only
when you must. Use only SAE Class ”S” type chains
that are the proper size for your tires. Install them
on the rear axle tires and tighten them as tightly
as possible with the ends securely fastened.
Drive slowly and follow the chain manufacturer’s
instructions. If you can hear the chains contacting
your vehicle, stop and retighten them. If the contact
continues, slow down until it stops. Driving too
fast or spinning the wheels with chains on will
damage your vehicle.
by SilverBullet1997 » April 20th 2015, 7:23am
by theGlasswalker [OP] » April 21st 2015, 6:25pm
AstroWill wrote:The user manual for my 03 doesn't differentiate:Tire Chains
I would prefer them on all tires, but that is just me.
by AstroWill » April 21st 2015, 6:57pm
theGlasswalker wrote:
It looks like it does differentiate. "Install them on the rear axle tires".
I keep forgetting about the users manual. It says the same in mine.
by Meterpig » April 21st 2015, 8:11pm
by Meterpig » April 21st 2015, 8:13pm
by AstroWill » April 21st 2015, 11:13pm
Meterpig wrote:If you were stopped, they would see you were AWD and you would roll on. Cops don't typically chase down moving vehicles in the snow.
Although, Washington can be weird about snow. When I was in Cali, they didn't require them and out here, AWD and 4WD chains are not required.
The main issue is, if you cause an accident and don't have chains or some other device, you WILL get a ticket.
I would never, and I mean never, put chains on my astro. If it's that bad to need chains, the National Guard would be out.
TYPES OF CHAIN CONTROL
During the winter months motorists may encounter traction device controls in the mountain areas of California. When chain controls are established, signs along side the road will be opened indicating the type of requirement. There are three requirements in California.
Requirement One (R1): Chains or snow tread tires required. Snow tires must have a tread depth of 6/32" with a "M & S" imprint on the tire's sidewall.
Requirement Two (R2): Chains required on all vehicles except four-wheel drives or all-wheel drives with snow tread tires on all four wheels. NOTE: four-wheel and all-wheel drive vehicles must carry traction devices in chain control areas)
Requirement Three (R3): Chains are required on all vehicles, no exceptions.
by Meterpig » April 22nd 2015, 6:54am
by Lumpy » April 22nd 2015, 8:37am
by theGlasswalker [OP] » April 22nd 2015, 5:59pm
AstroWill wrote:It does not differentiate between RWD and AWD, either way it says to put them on the rear. Should have made that clearer in my statement though I figured it was implied.
by AstroWill » April 22nd 2015, 11:58pm
Meterpig wrote:When I was in Cali, they didn't require them and out here, AWD and 4WD chains are not required.
Meterpig wrote:. I don't see a problem with what I said....but whatever whatever
by crgastro » June 25th 2015, 8:16am
by Jeepster09 » December 26th 2015, 3:53pm
by 4Zsnow » December 26th 2015, 5:31pm
Jeepster09 wrote:Back when I lived in State of Wyoming, I found running chains on front axle worked better than on rears, the added engine weight helped with traction. Running on just rears they just spun more in snow.
by Meterpig » December 28th 2015, 6:10am
It is currently February 25th 2021, 5:58pm
Wheels/Tires Forum |
Previous topic Next topic |
Sponsors |
