Clearcoating wheels?
Postby gejettest [OP] » June 12th 2010, 5:56pm
Hello,
Included are pictures of my wheels which are showing signs of aging.
I would like to renew the clearcoat, any tips?
Please note, I just washed the wheels, so the staining you see has permeated the old clearcoat.
Thanks,
Henry
gejettest
Years of Membership: gejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full years
Alias (AKA): gejettest
Van Model Year: 1996
Extra Info: 2wd 259k mi
  • Will 9 wide wheels fit?
    by GutchDuts » December 12th 2020, 9:28pm in Wheels/Tires
    December 16th 2020, 4:08am
  • Snow Chains on Front Wheels
    by jimi_lee » January 7th 2021, 7:08pm in Wheels/Tires
    Last post by dramey View the latest post
    March 18th 2021, 11:34pm
    9
    26
    April 23rd 2021, 12:29pm
Re: Clearcoating wheels?
Postby LEVE » June 12th 2010, 6:02pm
It's not going to last forever, but
  • Soda blast the wheels and then clear coat them.
  • Then in a couple of years... repeat.
LEVE
Years of Membership: LEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full yearsLEVE has been a member for 11 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby gejettest [OP] » June 16th 2010, 5:08am
Thanks for the tip,
Will the soda blasting dull the wheels? If so, will I have to polish them? Speaking of polishing, will clearcoat stick to a freshly polished wheel? I did a set of aluminum wheels some time ago, but after polishing I used a clear primer, I didn't like it as it gave the polished surface a cloudy, milky appearance that the clear only made permanent.
gejettest
Postby LEVE » June 16th 2010, 5:20am
Yes, you should polish them. However, remember that Aluminum oxidizes, almost immediately. It forms a anodized layer, I suspect that's what you're seeing; it could also be a reaction between the aluminum and the clear coat chemicals.
LEVE
Topics: 18
Return to Wheels/Tires
It is currently April 23rd 2021, 12:29pm
Wheels/Tires Forum
Attached by: chevymaher
in Wheels/Tires
Date: Apr 14 '21
Time: 12:10pm
in Wheels/Tires
Date: Apr 12 '21
Time: 11:52pm
Attached by: ssbf1
ssbf1
in Wheels/Tires
Date: Apr 12 '21
Time: 7:24pm
Macwicker
in Wheels/Tires
Date: Mar 20 '21
Time: 5:54pm
Jimmy111
in Wheels/Tires
Date: Mar 18 '21
Time: 12:10am
Users browsing this forum: gravelygravely is online! and 4 guests
