Studded with new rims
Postby Tgillespie [OP] » October 16th 2015, 4:25am
Hi so I am brand new owner of a 2000 AWD Astro and I live in Colorado. I want to have a better tire for snow driving, I am currently on stock 15's but want to upgrade to 16's for the greater variety. I want studded snow tires what is the best way to do this without spending an arm and a leg and still getting what I want? Rims and Tires.
Timmy
Tgillespie
Years of Membership: Tgillespie has been a member for 5 full yearsTgillespie has been a member for 5 full yearsTgillespie has been a member for 5 full yearsTgillespie has been a member for 5 full yearsTgillespie has been a member for 5 full years
Alias (AKA): Rooster
Extra Info: Awd
  • "New" rims
    by Tanino » January 8th 2021, 1:09am in Wheels/Tires
    January 9th 2021, 11:30pm
  • Nissan rims
    by Lowcountry » November 11th 2020, 12:01am in Wheels/Tires
    November 11th 2020, 4:54pm
    18
    March 3rd 2021, 3:56pm
Re: Studded with new rims
Postby Astrofarian » October 16th 2015, 1:10pm
Hi and welcome to the forum. I'm not sure about your neck of the woods but around here 15" rubber is still pretty widely available. Even Wally World has lots of options for 15" snow tires (Studding optional, of course) Take a look on CL in your area, you may be surprised what you'll find. Or is it snowing there already?
-Mike-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby Tgillespie [OP] » October 16th 2015, 7:09pm
Not snowing yet but everyone knows it's coming. I've just been reading and heard 16 had more options and sometimes cheaper. I also want to know what tire sizes I can get with 15s or 16s and drive unhindered.
Tgillespie
Extra Info: Awd
Postby Lumpy » October 16th 2015, 7:22pm
Tgillespie wrote:
... I also want to know what tire sizes I can get with 15s or 16s and drive unhindered.
[gets old I know]
Measure. You KNOW the dimensions of YOUR van. You KNOW the dimensions of your prospective tires. Put a tape measure on it. Your van isn't the same size and shape as anyone else's van, even if theirs is the same year/make/model.
If you want to know if something fits, measure the space you want to put it in.
Postby The Drummer » October 16th 2015, 7:47pm
I kinda fail to see why you would want studded tires , awd with new good winter tires is already very good in snow , but if you have to drive on high montain icy roads then its better breaking going down hill , there will be more slippery on cold pavement .
''USE THE TORQUE LUKE ''
and beware of trees ,them nasty wooden things are evil .
The Drummer
Years of Membership: The Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full years
Topics: 16
Images: 42
Extra Info: SLT 4.3 AWD
Postby Tgillespie [OP] » October 17th 2015, 12:22am
My driveway isn't always plowed with a natural spring that runs down it sometimes.
Tgillespie
Extra Info: Awd
Postby Lumpy » October 17th 2015, 4:42am
Tgillespie wrote:My driveway isn't always plowed with a natural spring that runs down it sometimes.
My driveway isn't always plowed with a natural spring that runs down it sometimes either.
:doh:
Postby ihatemybike » October 17th 2015, 4:03pm
You can get some steel 16" aftermarket rims in the 5x5 bolt pattern pretty easy. The Jeep Wrangler JK use the pattern. I picked up a set of 5 steel Pro Comp off CL fairly cheap from a JK owner.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Topics: 68
Postby Tgillespie [OP] » October 19th 2015, 8:21pm
:doh:
Then you must know exactly how I feel, thanks for the great comment.
Tgillespie
Extra Info: Awd
Postby Casey » October 24th 2015, 10:01pm
Timmy,
Go to http://www.tirerack.com and search for wheel and tire combos after entering your van's specific info. It's a great resource for tire reviews, and I've found it to be a fairly good guide when deciding which tires to buy. If you end up buying wheels and tires from them, they can mount, balance, and install the studs for you, so when they arrive, they are ready to mount on your van.
You know you need 5x5" bolt pattern, and you can determine the range of wheel offset/backspacing which will work with some simple math. For winter you won't want an 8" wide wheel anyway, so stick with the stock 5.5" or 6" wide wheels.
Most Jeep 5x5" pattern wheels have a very high positive offset (5.25" backspacing for some factory Wrangler wheels), much to high for our vans.
Casey
Years of Membership: Casey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full years
Topics: 24
Extra Info: 4.3L LT 5-speed
Postby Tgillespie [OP] » October 25th 2015, 2:40am
thanks dude.
Tgillespie
Extra Info: Awd
Postby Casey » October 25th 2015, 4:57pm
My advice would be to keep the stock 15" wheels and get the studded winter tires you want. I just bought a set of General Altimax Actic studdable (though I won't have them studded) winter tires, and there are some really good deals on new winter tires with free shipping on eBay, depending upon your tire size. Even from online sellers like Tire Rack, etc., 15" winter tires are in the $65-$100 range, so not too pricey. And, if you use the stock 15" wheels, you only need to purchase tires. You can always pick up a set of 16" tires for non-winter driving, too.
Casey
Topics: 24
Return to Wheels/Tires
It is currently March 3rd 2021, 3:56pm
Wheels/Tires Forum
Bikley
in Wheels/Tires
Date: Feb 27 '21
Time: 7:01am
in Wheels/Tires
Comments: 13
Date: Feb 17 '21
Time: 3:35am
YORKSTER02
in Wheels/Tires
Date: Feb 06 '21
Time: 3:57am
Lowcountry
in Wheels/Tires
Date: Jan 11 '21
Time: 5:58am
in Wheels/Tires
Date: Jan 08 '21
Time: 1:54am
