my long term project with the van has been a two inch lift so i can buy cooper at3 lt235/75/15 tires.
2" lift is done, i'm very slowly going through my front end and steering. i wire wheeled my whels today and found a stamp that says "1575 lbs max 35 psi"
35 psi is cut off in the pic
the cooper tires are rated over 1900 lbs and a lot higher than 35 psi. i was planning to underinflate them at 50 psi and tow my trailer
should i be looking at new wheels?
