Can i fitt 20 10×8 rins on my 03 safari?
Postby Sunday1990 [OP] » January 10th 2016, 10:57pm
Hi im new to this, im in a wheelchair and well have purchased a safari 03 wheelchair accessible van, im 26 & dont want it to look like everyother one so i have purchased a set or rims that are 20 inch width 10.8 wondering if anyone nos if i will have any issues just bolting these on! Help would be greatly appreciated
Sunday1990
Years of Membership: Sunday1990 has been a member for 5 full yearsSunday1990 has been a member for 5 full yearsSunday1990 has been a member for 5 full yearsSunday1990 has been a member for 5 full yearsSunday1990 has been a member for 5 full years
Alias (AKA): Colin
Van Model Year: 1990
Extra Info: 4.3 2003
  • Will 03 S 10 alloy rims fit on my 02 Safari
    by YORKSTER02 » February 6th 2021, 3:05am in Wheels/Tires
    Last post by astroracer View the latest post
    February 6th 2021, 11:14pm
  • 99 safari bolt pattern
    by KreepWorld » December 31st 2020, 12:43am in Wheels/Tires
    December 31st 2020, 5:16am
    7
    37
    February 25th 2021, 11:49am
Re: Can i fitt 20 10×8 rins on my 03 safari?
Postby Lumpy » January 10th 2016, 11:11pm
What size are the rims? I can't tell from your post.
Are they 20" diameter, 10" width? What does the 8 have to do with it?
What's the bolt pattern?
Postby Sunday1990 [OP] » January 10th 2016, 11:19pm
There the right bolt patter 6 bolt and deoth is exactly the same but the rims are alot bigger the ones on it are 17s factory gm rims the ones i found a decent deal on are 20inch 10.8 wide
Sunday1990
Alias (AKA): Colin
Postby Lumpy » January 10th 2016, 11:21pm
I'm pretty sure they won't fit.
Postby Sunday1990 [OP] » January 10th 2016, 11:22pm
The ones on it are just factory 6 bolt rims so i have found 20s that look nice but im not sure the 10.8 width will just bolt on & not rub
Sunday1990
Alias (AKA): Colin
Postby Sunday1990 [OP] » January 10th 2016, 11:23pm
Im going to call a rim shop tomorow but figured would be good to ask here
Sunday1990
Alias (AKA): Colin
Postby Sunday1990 [OP] » January 10th 2016, 11:24pm
Thank you budy
Sunday1990
Alias (AKA): Colin
Postby tedanderson » January 10th 2016, 11:29pm
Unless your rims have enough offset, they will rub. If they are offset too much or you put spacers behind them, then they will destroy your ball joints. Can you take a picture of them and/or measure your offset?
tedanderson
Firing on 8 Cylinders (L3)
Topics: 76
Alias (AKA): 2Big4aMiniVan
Postby markmitch » January 11th 2016, 12:20am
no they will rub and ride like a bulldozer with a broken suspension but hey if you think it looks cool, just remember to keep the stock wheels so when you sell the van you may get a buyer. I see vehicles on craigslist every day with huge rims and rubber band tires and they never sell simply cause only 2 percent of the worlds population likes the cartoon car look.
Firing on 8 Cylinders (L6)
Topics: 626
Images: 20
Extra Info: RS V8 AWD
Postby WoodButcher » January 11th 2016, 2:23pm
Welcome Colin,
Sorry, with the info you provide it isn't likely anyone can say for certain. You need to know the backspacing to begin with and even then if they did fit the best you could do would be the rubber band tire, awful ride. You'll find these vans ride and handle better with an SUV tire, big rubber and higher load rating. You can run them at the low end of the pressure ratings for a good ride and better handling if the van is not loaded heavy, if you need to tow or haul loads add air and they will be good.
Search through a member's threads here named "meetthespeakers". He lowered his vans and used 18 or 19" rims I don't recall but you will find good info.
BTW, stock rim on your van is 16" six lug, I don't know the bolt pattern size or the backspacing for the 3rd gen van.
WoodButcher
Firing on 5 Cylinders (L6)
Topics: 30
Images: 514
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby kennysmoke » January 11th 2016, 2:38pm
Sunday1990 wrote:There the right bolt patter 6 bolt and deoth is exactly the same but the rims are alot bigger the ones on it are 17s factory gm rims the ones i found a decent deal on are 20inch 10.8 wide
Stock rims on an '03 are 16 inch... if you have 17's they are not original...
"Live Free Or Die" Image
kennysmoke
Blue Status (L2)
Blue Status (L2)
Topics: 68
Images: 7
Alias (AKA): kennysmoke
Extra Info: AWD Tow Pakage
Postby AstroWill » January 12th 2016, 2:26pm
Simple answer is that you can make anything fit with enough work, but they surely won't fit on a stock van.
Images: 471
Postby Lumpy » January 12th 2016, 3:10pm
Not only will the wheels not fit, we haven't even heard a thing about the tires that will mount on the wheels. "Because they're a good deal" doesn't seem like a very good reason to buy a set of wheels. I would rather figure out exactly what look/size/style I want first - THEN - figure out what mods I'd have to make to get them to fit - THEN - finally search for the best deal.
Postby AstroWill » January 12th 2016, 3:20pm
Lumpy wrote:I would rather figure out exactly what look/size/style I want first - THEN - figure out what mods I'd have to make to get them to fit - THEN - finally search for the best deal.
I think they have a word for this, hmmm, logic?
Images: 471
Postby Lumpy » January 12th 2016, 3:44pm
New car sales violate that concept all the time.
SALESMAN:
"I've got a great deal for you on this pink AMC Pacer"
CONSUMER:
"But it's ugly as hell, won't carry the stuff I want to carry and I feel cramped when I sit in the driver's seat"
SALESMAN:
"Yes, BUT look at the great deal I can get you. $400/month for the next nine lifetimes"
CONSUMER:
"I'll take it"
Return to Wheels/Tires
It is currently February 25th 2021, 11:49am
Wheels/Tires Forum
in Wheels/Tires
Comments: 13
Date: Feb 17 '21
Time: 3:35am
YORKSTER02
in Wheels/Tires
Date: Feb 06 '21
Time: 3:57am
Lowcountry
in Wheels/Tires
Date: Jan 11 '21
Time: 5:58am
in Wheels/Tires
Date: Jan 08 '21
Time: 1:54am
Tanino
in Wheels/Tires
Date: Jan 08 '21
Time: 1:09am
