Harbor fright Strikes again
Postby ratdude747 [OP] » December 30th 2012, 5:40am
Not sure if this has been posted or not... (I know I could search for it)
But I'm damn lucky my HF jackstands didn't kill me.
http://www.harborfreight.com/3-ton-heav ... 38846.html
Thier stands are BS. Those ratings are BETWEEN BOTH STANDS. That's right, they actually are 1.5T stands, not 3T stands! :eek
You'd think they were 3T a pop since even the iron saddles say "3 TON". But If one reads the manual, it begs to differ.
I bought a set a few months back. I used them only once or twice... the really dinky saddles should have given it away...
They held the van Ok... but given what a fiasco the oil change was (I had to use a massive breaker bar to get out the drain plug), I could have been one vertical pull away from getting crushed.
At least I Only wasted $15 on them.
...and great, now I need to get both a decent jack AND some jack stands before my next oil change in 800MI. :screaming:
ratdude747
Years of Membership: ratdude747 has been a member for 12 full yearsratdude747 has been a member for 12 full yearsratdude747 has been a member for 12 full yearsratdude747 has been a member for 12 full yearsratdude747 has been a member for 12 full yearsratdude747 has been a member for 12 full yearsratdude747 has been a member for 12 full yearsratdude747 has been a member for 12 full yearsratdude747 has been a member for 12 full yearsratdude747 has been a member for 12 full yearsratdude747 has been a member for 12 full yearsratdude747 has been a member for 12 full years
Images: 10
Extra Info: CS 4.3L RWD
Re: Harbor fright Strikes again
Postby Shad0wXCalibur » December 30th 2012, 5:50am
I keep the jack underneath vehicle as well as the jack stand if im gonna be under it. My van sits high enough to not crush me though. Gotta love ground clearance.
1987 Astro
2000 Safari
Shad0wXCalibur
Years of Membership: Shad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full years
Topics: 41
Extra Info: Lifted 2wd
Postby RECox286 » December 30th 2012, 6:27am
$15 for a set of two jack stands ??? What do you want for $15 ??? Do they come with a guarantee ??? If they fail and you get kilt while
using them, do you get a free replacement set ???
Uncle Bob (Inquiring minds would like to know...)
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby Big_kid » December 30th 2012, 6:31am
I too keep the jack underneath in case I yank the vehicle off the stands somehow.
I went all out when I got my stands- Northern tool, but this was before EVERYTHING went to China. Even then it took 3 sets before getting a pair whose roll pins didn't shear the first time I used them.
Firing on 7 Cylinders (L7)
Topics: 185
Images: 337
Extra Info: 2WD 5.7 V8
Postby ratdude747 [OP] » December 30th 2012, 6:49am
Never mind... After some consultation, other than the tiny saddles, they're good.
ratdude747
Images: 10
Postby Shad0wXCalibur » December 30th 2012, 7:08am
Well figure 3 tons is 6,000 pounds. They should hold one end of an Astro up.
1987 Astro
2000 Safari
Shad0wXCalibur
Topics: 41
Postby GaryS » December 30th 2012, 7:29am
When I changed my oil, I drove up on blocks for the extra room needed.
GaryS
Years of Membership: GaryS has been a member for 8 full yearsGaryS has been a member for 8 full yearsGaryS has been a member for 8 full yearsGaryS has been a member for 8 full yearsGaryS has been a member for 8 full yearsGaryS has been a member for 8 full yearsGaryS has been a member for 8 full yearsGaryS has been a member for 8 full years
Postby esmartuek » December 30th 2012, 7:40am
And this is why I never buy anything I don't intend to break from HF... except their Chicago Electric stuff, that line has served me well. Everything else - disposable.
I'm sorry to hear that you had such a bad experience, though... I've seen 4x4 wood beam props perform as jack stands in a pinch just fine (I wouldn't recommend it, but I've seen it) Scary to think that a device sold for that purpose would fail at it's job.
esmartuek
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: esmartuek has been a member for 10 full yearsesmartuek has been a member for 10 full yearsesmartuek has been a member for 10 full yearsesmartuek has been a member for 10 full yearsesmartuek has been a member for 10 full yearsesmartuek has been a member for 10 full yearsesmartuek has been a member for 10 full yearsesmartuek has been a member for 10 full yearsesmartuek has been a member for 10 full yearsesmartuek has been a member for 10 full years
Topics: 5
Alias (AKA): Esmeatuek
Extra Info: 4.3L V6 AWD
Postby markmitch » December 30th 2012, 2:52pm
Check out the jack stands on Homedepot.com I have 8 of them cause I'm always working on more then one project. Mine have served me well.
Firing on 7 Cylinders (L6)
Topics: 622
Images: 20
Extra Info: RS V8 AWD
Postby RECox286 » December 30th 2012, 4:36pm
I'll come out of the closet...My 6T stands are from HF. They used to hold up a loaded P-30 GMC bread truck (10k gvw empty) so I guess they will
hold up a dinky Astro. I too, leave the jack under the truck, but having had one jack fail and the truck come down like gangbusters, I
will never rely on any jack, mechanical, pneumatic, or hydraulic. Fact be known, I'm somewhat leary of elephant ramps, to be honest.
True story: I was working in my driveway, one sunny day, and happened to look over at my next door neighbor who had complained that the
starter on his truck was toast. He had all my tools and equipment at his disposal, yet, he opted to jack up the front of the truck with a
bumper jack. The street has a bit of a downhill slope to it, and I doubt that the parking brake was set, or that it even was in working
condition. I didn't see chocks under the rear wheels, nor did he have blocking underneath the front wheel. You can guess where my
neighbor was... No, nothing happened, no blood on the street, no car sitting at the end of the block, and no rushed call for an EMT.
His truck, his jack, his starter, his body, his thought process. Needless to say, I have great respect for 'heavy things that go fast and
can kill in an instant', but I fear that most people just don't get it.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby redfury » December 30th 2012, 5:14pm
a pair of wheel chocks or the E brake at the very least should be used any time you are jacking up a vehicle. I had my 2.5 ton floor jack ( not the crappy trolley jacks you get at walmart ) roll on my driveway putting a nice dent on the underside of my wifes Grand Am once. Blocks of wood and wheel jacks are always around my driveway in the event they are needed.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby Big_kid » December 30th 2012, 5:22pm
I use my 1.5ton jackstands as wheel chocks.
Topics: 185
Images: 337
Postby RECox286 » December 30th 2012, 7:24pm
Amen Brethern, I see the light !
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby Starrshine » December 30th 2012, 7:30pm
I just love the people that use cinder blocks to jack their car up!
Bob
Be who you are and say what you feel because those who mind don't matter and those who matter don't mind. -- Dr. Seuss
Listen to my music here:
http://www.reverbnation.com/bobstarr
Starrshine
Years of Membership: Starrshine has been a member for 8 full yearsStarrshine has been a member for 8 full yearsStarrshine has been a member for 8 full yearsStarrshine has been a member for 8 full yearsStarrshine has been a member for 8 full yearsStarrshine has been a member for 8 full yearsStarrshine has been a member for 8 full yearsStarrshine has been a member for 8 full years
Images: 3
Postby thegreenmachine » December 30th 2012, 7:36pm
when my 89 crown vic was stolen for the 4 time they had used milk crates as stands to steal the wheels.
people still steal rims? or stereo's anymore?
seems like vehicle related theft has dropped off a lot around here....which is a good thing. i never take my faceplate off.
come to think of it though my 95 was broken into 3 times in 3 days.
"that looks legit"
95 AWD Safari money pit
thegreenmachine
Firing on 6 Cylinders (L2)
Years of Membership: thegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full years
Topics: 62
Alias (AKA): Shane a lane
Postby markmitch » December 30th 2012, 10:48pm
When I was 16 I had a 67 firebird I bought from a local junk yard, I had it jack =ed up with concrete blocks under the front and a scissor jack under the rear axle and no wheels or tires on it. I was under it and pulling on an exhaust pipe and something told me to move! I rolled out as fast as possible and the car crashed to the ground. All I got was a pinched shoulder which healed in about a week. Since then I have never climbed under a vehicle without jack stands. That is why I have 8 of them. And two hydraulic jacks. What good is a beautiful Vehicle if your to messed up to enjoy it due to your own stupidity?
Topics: 622
Images: 20
Postby Zebediah III » December 30th 2012, 11:19pm
Anyone who would trust their life to something from Harbor Freight is a fool.
Jackstands, engine hoists, ramps, trailers etc. NO WAY!
I could see buying a tarp from there, or some tie wraps but that's about it.
I've seen people hurt using their tools and I really don't feel sorry for them.
Zebediah III
Images: 16
Extra Info: 383 Crate Motor
Postby smokinjoe » December 31st 2012, 12:12am
Is this the flyer you ordered from?
smokinjoe
Firing on 5 Cylinders (L2)
Topics: 268
Alias (AKA): smokinjoe
Van Model Year: 2002
Extra Info: RWD
Postby RECox286 » December 31st 2012, 3:53am
Repeat after me: 1) "Never get under a hanging load !" 2) "Never get under a hanging load !" 3) "Never get under a hanging load !"
Pop quiz time...What are the 3 rules regarding hanging loads ?
Uncle Bob
C'mon now, I use a lot of HF stuff. You have to respect what you use and how you use it. That goes for SO, C'man, OTC, or any tool or
equipment mfg. I've seen failures of US, German as well as Chinese, etc made tools. What am I to do, stay in bed, or slip in the shower ???
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby ratdude747 [OP] » December 31st 2012, 4:34am
I'll probably keep using the Harbor Freight stands. The $89 It will run me for a 3T trolley Jack (also from Harbor Freight) is $$$ enough... And even that I'm having to consider the costs on.
On one hand, I could keep using the spare jack to lift the van onto the jackstands... On the other, doing that is a massive PITA and probably is outside what the spare jack was meant to do.
ratdude747
Images: 10
  • RockAuto Less Friendly - AGAIN
    by Lumpy » November 4th 2015, 10:50pm in Member Reviews
    November 5th 2015, 2:45am
    17Replies
    56Replies
    January 19th 2021, 12:52pm
  • Rock Auto *again*
    by AndyH » January 12th 2016, 9:13am in Member Reviews
    September 28th 2016, 9:51pm
Return to Member Reviews
It is currently January 19th 2021, 12:52pm
Member Reviews Forum
Member ReviewsTell about your experiences! Who to buy from and who to stay away from. If there are excellent shops in your area make sure you share your experiences with any products or services here; good or bad!
To create a new topic in Member Reviews, click this button:
fabinator
in Member Reviews
Comments: 59
Date: May 07 '19
Time: 5:28am
Attached by: chevymaher
in Member Reviews
Comments: 59
Date: Feb 07 '17
Time: 12:59pm
in Member Reviews
Comments: 59
Date: Feb 07 '17
Time: 3:41am
in Member Reviews
Comments: 17
Date: Jan 21 '17
Time: 1:20am
in Member Reviews
Comments: 17
Date: Jan 20 '17
Time: 10:26am
cron
