I have just removed the body cladding from my van and have the blisters on my thumbs to prove it! (rubbing off the adhesive)
The cladding is light autumn wood aka brown and in pretty good shape. Looked great on the van. There has been some slight modification some on purpose some on accident attached pictures detail particulars. Jackknifing utility trailer creased right rear panel and i trimmed away parts of the left front wheel well (rear portion). But this was done carefully so as to not be obvious to the casual observer. It looks fine it's just not symmetrical w/ the right front. Could be perfect if your having clearance issues on your left front tire.
Includes all the parts and pieces-rubber/plastic inner sheets, metal backing plates, screws, and platic fasteners.
I'd like to get a hundred for the pile to off-set the cost of the front filler pieces i now need to make the van look right. If you have those we might be able to work out a trade.
I'm near Lancaster, CA and can deliver to LA during visits to the area. Thanks!
