TransGo '93-'96 4L60E Shift Kit + Lots of Extras - $300.00
Always remember this is the internet folks. People get scammed every day (although, thankfully not here). Be aware of who you are dealing with and the product you're potentially buying. A little common sense goes a long way.
SCAMMERS BEWARE- We cooperate fully with users who have been defrauded. All IP Addresses are logged so just don't even bother.
Postby Casey [OP] » December 16th 2009, 4:59am
I have a bunch of TransGo shift kit parts used for about 750 miles in a '95 GM 4L60E transmission. TransGo Stage 2 shift kit, Corvette servo, The Beast sunshell, new 1-2 and 3-4 shift solenoids, new clutches, steels, new oil pump and bushings, new one-piece input shaft seals properly sized/installed by a local trans shop, etc. Bascially, I bought a $482.00 hi-po rebuild kit from ProBuilt Automatics in Costa Mesa, Ca, plus I bough the TransGo separator plate, Corvette servo, and The Beast sunshell, two new shift solenoids, etc.- over $650.00 worth of parts.
What's shown in the four pics is only a sampling of what I have. Please ask if you want to know if I have a specific part(s) and I'll let you know ASAP.
The improvement in shift quality was very niticeable, with firm, quick shifts and easy engagement of overdrive. It was a huge improvement over the stock parts. Unfortunately, one of the rear bearings siezed and I made the switch to a T-5 manual trans, so the 4L60E was a stripped and what's left are the parts I have.
These parts will fit '93-'96 GM 4L60E transmissions in C/K pickups, Astro/Safari vans, full-size G-vans, Impalas, etc. The parts will need a quick wash in solvent to remove any residue (the filter caught 99% of the debris from the bearing failure), but everything appears to be in good shape. I have the complete valve body ready to install, or switch the pieces over to your vavle body if you wish. The '95 VB I have has only 95K miles on it so it's in good shape.
I have an ATSG service manual and full instruction from TransGo for the shift kit I will include. I would prefer everything to go to one person as that would make it much easier, but I will sell individual parts or groups of parts separately if necessary.
I have extra parts from a '94 4L60E I purchased, as well as some of the stock parts left over from the '95- two stock sunshells in great shape, a '94 valve body and the stock valves from both the '94 and '95, VB bolts, an extra pan, and a mainshaft.
I also have a like-new flexplate that I installed when I re-installed the trans, so it also has about 750 miles on it. Absolutely nothing wrong with it, and bolts are included. I replaced my old one thinking it had the tyival cracking causing the rattling noise- no such luck...so now I have two good flexplates. :dunce:
If you're planning to rebuild your 4L60E or just improve its shift quality, this is a great deal on what you'll need.
I'm just north of Milwaukee, so anyone local that wants to stop by and check out what I have is welcome to do so. I can probably meet you around the metro Milwaukee area if that helps, too. :wave:
Thanks,
Casey
Casey
Years of Membership: Casey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full years
Topics: 24
Extra Info: 4.3L LT 5-speed
Re: TransGo '93-'96 4L60E Shift Kit + Lots of Extras - $300.00
Postby Casey [OP] » December 30th 2009, 5:47pm
Make me an offer on any of this stuff if you're interested. I'd like to get it to someone who can use it! :layrubber:
Casey
Topics: 24
Return to Parts/Accessories For Sale
It is currently September 26th 2020, 6:29pm
Parts/Accessories For Sale Forum
Parts/Accessories For SaleSell Parts For Astro and Safari Vans, Accessories, Auto Parts, Replacement, OEM, Performance Parts, Salvage, Aftermarket.
To create a new topic in Parts/Accessories For Sale, click this button:
Time: 3:42am
Time: 12:00am
Comments: 0
Date: Sep 21 '20
Time: 6:04am
Date: Sep 18 '20
Time: 6:49am
Comments: 83
Date: Sep 14 '20
Time: 6:50pm
