1993 AWD Trans No 2-3 upshift
Postby guitarjam6 [OP] » February 9th 2011, 11:47pm
Evening gents. I've found plenty of 4L60-E info, but was wonder if the 1993 AWD had a 4L60 or a 700r4?
My van is in what appears to be limp mode. First and second pull fine and shift fine, but the van will not shift up from 2nd to 3rd gear. Prior to the issue, it pulled and shifted fine in all gears, it was an immediate occurrence. I believe it's a solenoid, but there are 6 of them on rockauto. I'm not sure which one to go for. Thanks for your insight.
ACDELCO Part # 25242236 More Information About this Part {#08682007, 24242236, 8682007} replaces 8682007
CLAMP,PRESS CONT SOL VLV w/4-SPD A/TRANS(M30)- Stocked in outlying warehouse--shipping delayed up to 1 business day
$4.24
ACDELCO Part # 2141893 More Information About this Part {#19139323} [SOLENOID,TRANS 1-2, 2-3 SHIFT SOL
$14.02
ACDELCO Part # 24230298 More Information About this Part {#10478131, 24236521} replaces 24236521
VALVE,1-2,3-4 SHFT SOL w/4-SPD A/TRANS(M30)
$15.07
ACDELCO Part # 24227792 More Information About this Part {#24212690} VALVE,3-2 SHFT SOL w/4-SPD A/TRANS(M30)
$30.99
ACDELCO Part # 26042494
SOLENOID,A/TRNS SHFT LK CONT w/TILT STRG COL(N33)
$48.79
ACDELCO Part # D3988A More Information About this Part {#19138846} W/HARNESS
SOLENOID,TRANS
$56.79
ACDELCO Part # 8683434 More Information About this Part {#08683434}
VALVE,PRESS CONT SOL w/4-SPD A/TRANS(M30)
$105.79
guitarjam6
Years of Membership: guitarjam6 has been a member for 11 full yearsguitarjam6 has been a member for 11 full yearsguitarjam6 has been a member for 11 full yearsguitarjam6 has been a member for 11 full yearsguitarjam6 has been a member for 11 full yearsguitarjam6 has been a member for 11 full yearsguitarjam6 has been a member for 11 full yearsguitarjam6 has been a member for 11 full yearsguitarjam6 has been a member for 11 full yearsguitarjam6 has been a member for 11 full yearsguitarjam6 has been a member for 11 full years
Extra Info: 4.3L CPI AWD
  • 1997 AWD - can you assist re my trans/ xfer case
    by swing » October 26th 2020, 6:01am in Automatic
    October 29th 2020, 10:44pm
  • 1989 4.3 Trans Fluid Capacity
    by Slime » October 19th 2020, 5:30pm in Automatic
    Last post by Slime View the latest post
    October 19th 2020, 6:50pm
    9
    93
    February 25th 2021, 9:11am
Re: 1993 AWD Trans No 2-3 upshift
Postby Phantom » February 10th 2011, 12:34am
Enter your VIN in the link and it will tell you all the options your van was built with including the transmission , as there were a few options
http://www.compnine.com/vid.php?vin=1gndm19w5xb126525
the M30 is the 4L60E
i think the 700R4 is MD8
Phantom
Firing on 7 Cylinders (L4)
Postby guitarjam6 [OP] » February 10th 2011, 1:33am
Thanks! Checked it out. It's the M30 4L60E trans. Didn't think those came in a 93, but great, I hear that's the better option of the two.
guitarjam6
Postby Leeann_93 » February 10th 2011, 3:24am
All 93s came with the 4l60E - it was the first year for it.
Return to Automatic
It is currently February 25th 2021, 9:11am
Automatic Forum
AngryPunk
in Automatic
Date: Feb 18 '21
Time: 11:47pm
Youngblood
in Automatic
Date: Jan 15 '21
Time: 1:24am
allenstoltzfus
in Automatic
Date: Jan 14 '21
Time: 7:36pm
runawayjim
in Automatic
Date: Jan 07 '21
Time: 2:09pm
Attached by: SportsBoy
SportsBoy
in Automatic
Date: Jan 05 '21
Time: 11:16pm
