can any rwd 2000 and up 4L60E be swapped?
Postby weather [OP] » January 27th 2017, 4:30pm
I was ready to buy a tranie swap out at LKQ, but they won't warranty it if the 4L60E is from another type of vehicle, like a colorado, canyon or express. I don't get it. Aren't all of these 2000 and up rwd 4L60E'sinterchangable. TLKQ says they are on theHollander computer program and the program doesn't allow just any 2000 up 4L60E. That greatly limits my search for a low miles trannie. I could have gotten a 2012 canyon 4L60E with just 24k mikes on it, but they won't sell it to me with a warranty.
You did not evolve! censored-science.org
weather
Years of Membership: weather has been a member for 7 full yearsweather has been a member for 7 full yearsweather has been a member for 7 full yearsweather has been a member for 7 full yearsweather has been a member for 7 full yearsweather has been a member for 7 full yearsweather has been a member for 7 full years
Topics: 12
Alias (AKA): weather
Extra Info: Astro LT RWD
Re: can any rwd 2000 and up 4L60E be swapped?
Postby dkGarnet96 » January 27th 2017, 6:10pm
I'm not sure if I would go with a 2012 4l60e in your 2000. I think the electronics/sensors changed alittle after 2007. Obviously try and get one closer to your year, but I think you can go up to 2007 or 08. Also, the front removable bell housings and front output shaft on the newer 4l60es can be slightly different( I can't remember when they changed output shaft lengths, I think in 02 or 03)....just make sure the bell housings are the same height/depth and the end of the front output shafts look the same( there are two different styles, and they are different lengths) the bell housings are interchangeable so you could use your original one still if you want....the front output shafts are also interchangeable but requires taking apart the trans
front output shafts, look at the ends
front output shaft.jpg (12.67 KiB) Viewed 372 times
Other than that, as long as its from a RWD it should fit right in.
Something I noticed on my van, its on its 3rd trans.. factory trans lasted till about 170k miles, first rebuild lasted about 100k, new rebuild has about 20k and I hope it goes till 100k. Just food for thought while your shopping for a trans.
-96 AWD 350k- R.I.P with a spun bearing
dkGarnet96
Years of Membership: dkGarnet96 has been a member for 5 full yearsdkGarnet96 has been a member for 5 full yearsdkGarnet96 has been a member for 5 full yearsdkGarnet96 has been a member for 5 full yearsdkGarnet96 has been a member for 5 full years
Images: 6
Van Model Year: 1996
Extra Info: 4.3 awd
Return to Automatic
It is currently February 26th 2021, 7:58pm
Automatic Forum
AngryPunk
in Automatic
Date: Feb 18 '21
Time: 11:47pm
Youngblood
in Automatic
Date: Jan 15 '21
Time: 1:24am
allenstoltzfus
in Automatic
Date: Jan 14 '21
Time: 7:36pm
runawayjim
in Automatic
Date: Jan 07 '21
Time: 2:09pm
Attached by: SportsBoy
SportsBoy
in Automatic
Date: Jan 05 '21
Time: 11:16pm
Users browsing this forum: Google [Bot] and 9 guests
