1999 Astro 4L60E 3-4 slipping ...
Postby gene_sc [OP] » April 16th 2011, 5:01pm
Hi, new user here...
I have a 1999 Astro 4L60E with 3-4 slipping, Seems to have had a slight slipping issue in Drive over the last year (in the past I topped off the fluid and it was good to go). Was going down the freeway the other nite and trans started to slip badly in D & 3 (1,2 and passing gear work). Added a quart of fluid (turns out is was overfull) and limped it home. Dropped the pan expecting to find a bunch of material in the pan, but was only a very small amount of metal, no chunks ect, slight burnt smell.
I read the 4L60E common troubles posted on this site. From that info, seems I burned up the 3-4 clutches.
Looking for confirmation of the 3-4 clutches... as I expected a bunch of clutch material in the pan, could overfilling cause any of these symptoms? Anything else I can look at? If this was a T350 or T400 and I found such a small amount of material in the pan I would change the filter and add a can of Seafoam.
thanks,
gene
1999 Astro cargo 297K miles
EDIT: I did try my AutoXray scanner and it seems that it doesn't scan trans codes, also checked fuses underhood(all good)
gene_sc
Years of Membership: gene_sc has been a member for 9 full yearsgene_sc has been a member for 9 full yearsgene_sc has been a member for 9 full yearsgene_sc has been a member for 9 full yearsgene_sc has been a member for 9 full yearsgene_sc has been a member for 9 full yearsgene_sc has been a member for 9 full yearsgene_sc has been a member for 9 full yearsgene_sc has been a member for 9 full years
Alias (AKA): gene
Extra Info: 2wd 297K miles
Re: 1999 Astro 4L60E 3-4 slipping ...
Postby ihatemybike » April 17th 2011, 10:42pm
If you serviced you trans regularly you won't see much in the pan as it's cumulative wear on the 3-4 clutch pack. Main reason for the wear is the soft shifting they set these trans up with so it's hard to feel when the gear changes happen.
I had to have Green's transmission rebuilt because of this. If you are able to drop the trans yourself you can save a lot of money. I was able to find a small rebuilding shop near me that did the job, with serious upgrades for less than a grand.
http://www.shiftritetransmissions.com/4L60Ea.htm
If you haven't done it already add some Lucas Transmission Fix. It's a friction modifier that will buy you some time. It's made Grumpy's slipping trans work well enough for some off road climbing fun. Last year on the BABE Rally a group of guys in a full size van complained that there trans shifted from 2nd directly to 4th, had them add Lucas and their trans functioned normally again.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Topics: 68
Postby Phantom » April 17th 2011, 10:52pm
ihatemybike wrote: I was able to find a small rebuilding shop near me that did the job, with serious upgrades for less than a grand.
Wow that is a great deal , what is the name of the place that does rebuilds with serious upgrades for less than a grand , is it the same place as the link you give?
Thanks
It seems from the webpage they may not do Front Wheel drive trans , they have price listed but no info at all on any like they do for the RWD , wonder if they no longer offer
Phantom
Firing on 7 Cylinders (L4)
Postby ihatemybike » April 18th 2011, 12:07am
Yeah, Shift Rite is the place that did Green's trans. I had them do all the hot rod upgrades. Trans slams the shifts hard, wife doesn't like it. If I get into it I'll break the tires loose for the 1-2 and 2-3 shifts.
The owner of Shift Rite (Brett) is not that great at website programming. He says that while RWD are their bread and butter, they don't have a problem doing FWDs. Says his busiest time is during plowing season. I've been told he'll walk me through a rebuild for Grumpy if done during his off season. I'll be paying the normal rebuild price while doing this.
Aaron
ihatemybike
Topics: 68
Postby Phantom » April 18th 2011, 1:29am
That would still be worth it , knowledge and experience , in the future you can do it for free labor and maybe do some for others who need help :thumbup: :rockon:
Phantom
Postby gene_sc [OP] » April 18th 2011, 2:36am
Thanks for the replies... did a filter and fluid change, still slips.... Pulled the trans this afternoon, Found a couple used trans for $375 one with 117K and one with 70K on a factory reman...
gene
gene_sc
Alias (AKA): gene
Return to Automatic
It is currently January 23rd 2021, 7:39am
Automatic Forum
Youngblood
in Automatic
Date: Jan 15 '21
Time: 1:24am
allenstoltzfus
in Automatic
Date: Jan 14 '21
Time: 7:36pm
runawayjim
in Automatic
Date: Jan 07 '21
Time: 2:09pm
Attached by: SportsBoy
SportsBoy
in Automatic
Date: Jan 05 '21
Time: 11:16pm
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
