Patient is a 2004 Astro AWD (2nd and 3rd GEN) (First GEN may require different ID cooler hose )
Buckle up!
Hayden Ultra Cool Part #403 Comes with 11/32 hose and all the goods.
7mm
8mm
10mm
1/4"
Phillips
Cutters
Lube
wire loom
The extra Vacuum line you got laying around from replacing your broken plastic lines!
Knife
Pick
Marker/Turn Light Blubs 194 and 2057 IIRC
First step is to remove the air box, upper fan shroud and both cooler lines. Might as while clean that Mass air flow sensor since you got it off. Use your pick to take out the metal clips. Spray those clips with some sauce, makes getting them out a little easier. Some times the clips will wear a grove in the line and the can be PITA to get out... Hang in there! Sauce it up some more and remove that Grill! Now is a good time to check on those bulbs! LED time?
I put the vac line in Vise and sliced it. Run a longer piece around that whole opening. I was originally going run the cooler line underneath radiator but thought about the possibility of the Van running into to something.
Lube up the inside of the line a bit. I also stretched out the end of the hose a little bit to get it over the flare. It doesn't just slip on there trust me, your going to need to twist it back and forth a lot. Keep twisting you almost got it! I used two clamps for peace of mind but after getting the line on there you'll realize you only need one clamp.
Take the 4 10mm bolts out of the condenser. Now you can lift the left side of the radiator up and out towards the engine. This will give you access to put the clips on the back of the fasteners for the cooler. Might have to massage that A/C line a bit. I put the loom on there because this isn't my Van and we don't want leaks!
Next mock up where you want it and put the foam spacer pads on and shove the plastic rods through them.
I think if it was my van I would of hit it with a little black paint.
Now make sure you new bulbs work, slap your grill back on and fight that fan shroud in!
