RWD to AWD swap
RWD to AWD swap
Postby 68cuda [OP] » October 19th 2011, 6:58am
Hi there. I have low mileage ( 120ish k km ) 93 RWD that is in very good shape and a 93 AWD that is very rough cosmetically read rusty body but has a newly rebuilt t-case, front diff new cv joints etc. How much work would it be to take the AWD portion from the one van and install it in the other?
Thanks for any advice and BTW I have more time than $$ currently since I bought a house. I also need to justify all of the tools I have purchased in the last few months
68cuda
Years of Membership: 68cuda has been a member for 9 full years68cuda has been a member for 9 full years68cuda has been a member for 9 full years68cuda has been a member for 9 full years68cuda has been a member for 9 full years68cuda has been a member for 9 full years68cuda has been a member for 9 full years68cuda has been a member for 9 full years68cuda has been a member for 9 full years
Alias (AKA): Techman
Extra Info: 4.3 auto van
  • 1997 AWD - can you assist re my trans/ xfer case
    by swing » October 26th 2020, 6:01am in Automatic
    October 29th 2020, 10:44pm
  • Where to get 2005 AWD shifter cable ?
    by astrofinland » January 5th 2021, 4:50pm in Automatic
    Last post by astrofinland View the latest post
    January 7th 2021, 3:01pm
    33
    April 14th 2021, 12:10am
Re: RWD to AWD swap
Postby ihatemybike » October 19th 2011, 12:10pm
While we usually steer people away from the RWD to AWD convertion, you already have the donor, I'm saying go for it. Seeing that they are the same year it should be pretty straight forward. You'll be swapping sub-frames and all the suspension and drivetrain components and transmissions.
I'm guessing the easiest thing would be to pull both sub-frames with the engine and everything attached, swap engines, then put install the sub-frames assemblies in opposite vans.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Topics: 68
Return to Automatic
It is currently April 14th 2021, 12:10am
Automatic Forum
Bikley
in Automatic
Date: Mar 29 '21
Time: 5:42am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:49am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:42am
in Automatic
Date: Mar 01 '21
Time: 7:14pm
AngryPunk
in Automatic
Date: Feb 18 '21
Time: 11:47pm
