1994 AWD ASTRO CS 4.3L "W" 460LE
Van is about to hit 262,000, and things are failing faster than I can fix.
I won't go through that whole list right now.
But,
Most recently, the Hatch Window/Glass shattered, for no apparent reason.
Currently~
Today we drove for 50 Miles, during a hot day and Stopped at a 711. Backed out of the parking space and the van wouldn't move forward...
I tried all available gears (Automatic) and was able limp it out of the way, in 2nd.
Insurance payed for an 11 Mile tow, leaving us with the rest of the $167 tab. Thanks, USAA. Sigh.
Symptoms~
Reverse works perfectly fine.
Drive, Overdrive, 1 & 2, DO NOT.
2 can actually move the van forward, but a snail will win that race.
1 is even slower, barely moves it.
Overdrive and Drive does nothing, unless you give it gas to uncomfortable/potentially catastrophic levels. Then it jerks forward and you can hear a faint mechanical whine/rotational resistance from underneath briefly.
No trouble codes.
Despite being changed at appropriate intervals, the Trans Fluid was slightly dull/dark. Filter has been changed in the last 1000 miles.
Physically, the tail end of the tranny/transfer case is damp and has clearly been throwing fluid from the driveshaft connection area.
I'll be further investigating this.
Beyond changing fluids and general upkeep, I've never really had to deal with the AWD stuff. At this time I'm not terribly knowledgeable in that area. I'll be doing some studying.
But,
Do I actually have a Trans problem? Or
Could it be related the AWD stuff? Both???
It's acting like it still wants to move forward, and can (sort of, See above). But, with EXTREME resistance.
The only thing it was doing out of the norm, was an ocassional...Stumble? sometimes with a little lurch/jerk (hard to explain) at the end of a complete stop. I thought it might be the Idle not adjusting correctly.
I'll be fixing this myself.
I was already just about to tackle a Blown Headgasket on our second car.
I'm now under extreme pressure to have a running vehicle again, both are down, money is tight and I'm not sure which vehicle is worse at this point.
