UGH OH - Got stuck in gear and then it spewed tranny fluid..
Postby castlerox [OP] » May 20th 2018, 3:52pm
Hi All,
So yesterday upon helping my friend move I was driving along about 40mph when I noticed my engine was still engaged in a gear when I removed my foot from the pedal.
It was a little startling because I had to brake pretty heavily to slow it down. I reached down and the actual pedal was still down. I grabbed it and pulled it back but the van was still jamming along on its own. I was able to pull in to a safe spot. I put it in neutral and oh boy, the thing started REVVING like crazy. I could barely get it in to Park before I was able to shut her down.
After exterior inspection... The pink fluid was slowly flowing out from the front end.
I had to leave the scene so I had it towed to a friends shop.
Any initial ideas before the bad news tmrw?
Thanks in advance!
Matt
1998 AWD LT
1991 Montero GEN 1 LS
2007 Yamaha XT
Phoenix/Flagstaff, AZ
castlerox
Years of Membership: castlerox has been a member for 7 full yearscastlerox has been a member for 7 full yearscastlerox has been a member for 7 full yearscastlerox has been a member for 7 full yearscastlerox has been a member for 7 full yearscastlerox has been a member for 7 full yearscastlerox has been a member for 7 full years
Topics: 32
Images: 2
  • Lost Reverse & 2nd Gear, Ecode752=Shift Solenoid A stuck on
    by RandyHip » September 21st 2020, 9:03pm in Automatic
    September 21st 2020, 10:26pm
  • GEAR SHIFTER STUCK IN PARK.
    by huddy » October 18th 2020, 2:04pm in Automatic
    October 22nd 2020, 7:30pm
    11
    November 27th 2020, 9:38am
Re: UGH OH - Got stuck in gear and then it spewed tranny flu
Postby 90safari » May 20th 2018, 4:49pm
Something is causing the throttle pedal to hang open. It could be a kink in the cable, or something fell (a piece of insulation) that is causing it to not return to idle.
As for the leak, it sounds like the front seal is kaput. You'll have to separate the engine from the trans, and remove the trans, so you can pull the torque converter and replace the seal. Then put it all back together and top up the trans fluid.
867378671386681
90safari
Firing on 1 Cylinder (L2)
Topics: 5
Images: 160
Van Model Year: 1990
Extra Info: plus an 88 Astro
Postby Mmusicman » May 22nd 2018, 5:43pm
You didn't get "stuck in gear".. it sounds like your throttle simply got stuck.
Usually the best solution, once you've safely stopped, is to shut the key off first, and find the problem. Last weekend my throttle stuck on my 92, I shut the key off and coasted to a stop.
Not sure if over-revving the engine just pushed out some fluid or not.
You may have also temporarily overheated the trans while you were braking with the throttle still applied. There's a fair chance that there is no damage.
Good luck
Firing on 6 Cylinders (L5)
Topics: 73
Images: 49
Return to Automatic
It is currently November 27th 2020, 9:38am
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
