Sometime shifts hard , Turn off at red light shifts fine?
Postby AstroVanDan [OP] » August 14th 2018, 2:50pm
Two years ago I had my transmission rebuilt , when I got it back it shifted very hard . Took it back and reprogrammed the computer and it was fine . Now and then now it will shift hard at 55, 65, 70, 75. I can stop at a red light turn it off and restart and its fine. This happens a few times a week. What do you think? Thanks
AstroVanDan
Years of Membership: AstroVanDan has been a member for 5 full yearsAstroVanDan has been a member for 5 full yearsAstroVanDan has been a member for 5 full yearsAstroVanDan has been a member for 5 full yearsAstroVanDan has been a member for 5 full years
Topics: 9
Images: 4
Alias (AKA): AstroVanDan
Van Model Year: 2001
Re: Sometime shifts hard , Turn off at red light shifts fine
Postby plymouthcranbrook » August 14th 2018, 3:07pm
Probably a computer issue. Our school buses do that often and need a "reboot" done by turning of the engine and waiting a couple of minutes to restart. usually fixes it till the next time.
Last edited by plymouthcranbrook on August 15th 2018, 3:57am, edited 1 time in total.
plymouthcranbrook
Years of Membership: plymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full years
Topics: 16
Extra Info: allwheel drive
Postby AstroVanDan [OP] » August 14th 2018, 3:09pm
That's what mine is doing .
AstroVanDan
Topics: 9
Images: 4
Postby MattB » November 12th 2018, 1:43am
Around 1998 GM modified the 4L60e with a Soft Apply Torque Converter Function. After a bunch of miles the Valve wears and causes Slippage. The Computer calculates Slippage and Jacks up line pressure to correct this. This results in the Slam Shift 1-2. There is an easy/cheap fix for this. This kit coil-binds the PWM valve, eliminating the Soft Apply function. This fixed my Slam shift problem. The problem did major damage to the clutch pack. Full rebuild soon followed.
I haven't post the pics yet. Full 4l60e rebuild.
"Which is worse, The Evil you know or The Unknown?"
MattB
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: MattB has been a member for 3 full yearsMattB has been a member for 3 full yearsMattB has been a member for 3 full years
Images: 20
Alias (AKA): MattB
Extra Info: Rwd SLE
Return to Automatic
It is currently February 27th 2021, 1:53pm
Automatic Forum
AngryPunk
in Automatic
Date: Feb 18 '21
Time: 11:47pm
Youngblood
in Automatic
Date: Jan 15 '21
Time: 1:24am
allenstoltzfus
in Automatic
Date: Jan 14 '21
Time: 7:36pm
runawayjim
in Automatic
Date: Jan 07 '21
Time: 2:09pm
Attached by: SportsBoy
SportsBoy
in Automatic
Date: Jan 05 '21
Time: 11:16pm
Users browsing this forum: Google Adsense [Bot] and 13 guests
