4l60e transmission slipping? TCC Valve or Solenoid?
Postby californiaastroluv76 [OP] » October 30th 2018, 4:55am
What up guys was looking into why my transmission is slipping. Had seen online that it would be my TCC PWM Solenoid or maybe getting spring for the TCC Valve? Hmm.......
Years of Membership: californiaastroluv76 has been a member for 8 full yearscaliforniaastroluv76 has been a member for 8 full yearscaliforniaastroluv76 has been a member for 8 full yearscaliforniaastroluv76 has been a member for 8 full yearscaliforniaastroluv76 has been a member for 8 full yearscaliforniaastroluv76 has been a member for 8 full yearscaliforniaastroluv76 has been a member for 8 full yearscaliforniaastroluv76 has been a member for 8 full years
Topics: 47
Re: 4l60e transmission slipping? TCC Valve or Solenoid?
Postby Meterpig » October 30th 2018, 8:04pm
What gear is slipping?
Meterpig
Firing on 5 Cylinders (L2)
Years of Membership: Meterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full years
Topics: 63
Alias (AKA): meterpig
Van Model Year: 2002
Extra Info: Not a minivan
Postby californiaastroluv76 [OP] » October 30th 2018, 9:05pm
2nd gear or when I'm on Overdrive
Topics: 47
Postby akforceten » October 30th 2018, 9:17pm
the same thing happened to me in my 97 ended up just replacing the trans
98638 100250
akforceten
Years of Membership: akforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full years
Topics: 32
Images: 128
Alias (AKA): akforceten
Extra Info: SLE 4x4 7 inch lift
Postby californiaastroluv76 [OP] » October 30th 2018, 9:48pm
Well I've read it's probably either the TCC Pwm Solenoid and also the TCC valve. It's a common thing. I'm debating if I shud just get a new refurbished valve body with all the upgrades. Don't have the cash to get it rebuilt
Topics: 47
Postby akforceten » October 30th 2018, 10:04pm
I just used a JY trans. when my overdrive started slipping I had to finish driving home from Salem to Bend OR in second gear. the trans still worked sorta it had a bad burnt smell to it so opted to replace it
98638 100250
akforceten
Topics: 32
Images: 128
Postby Meterpig » October 31st 2018, 5:08am
Typically the solenoids will go before the hard parts. A shop will probably charge $500 for the valve body and the solenoids.
Meterpig
Topics: 63
Postby californiaastroluv76 [OP] » November 3rd 2018, 12:05am
awesome might get a refurbished valve body or just end up replacing the valve and solenoid. Also, i noticed my ABS light is on. I noticed that sometimes an ABS wheel sensor might be the cause for the transmission to acting up. Is this true? :(
Topics: 47
Postby CopperFiremistCopperFiremist is online! » November 3rd 2018, 12:33am
I would drop the pan and look for material in the bottom of it, most likely the trans needs to be rebuilt.
Pullin The Pass
Firing on 1 Cylinder (L2)
Topics: 25
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Postby MechBob » November 3rd 2018, 1:13am
CopperFiremist wrote:I would drop the pan and look for material in the bottom of it, most likely the trans needs to be rebuilt.
I agree.Probably a 2-4 band problem.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby californiaastroluv76 [OP] » November 4th 2018, 3:52pm
when u say 2-4 band problem isn't that the servo? i did replace the servo a few months back with a corvette servo? is that what is causing my slipping then?
Topics: 47
Postby Meterpig » November 4th 2018, 6:37pm
The servo is mechanical and controlled by diverted pressure. It's unusual for it to malfunction. Seriously, take it to a real shop that doesn't have the answer of "rebuild it" every time.
Meterpig
Topics: 63
Return to Automatic
It is currently January 22nd 2021, 4:45am
Automatic Forum
Youngblood
in Automatic
Date: Jan 15 '21
Time: 1:24am
allenstoltzfus
in Automatic
Date: Jan 14 '21
Time: 7:36pm
runawayjim
in Automatic
Date: Jan 07 '21
Time: 2:09pm
Attached by: SportsBoy
SportsBoy
in Automatic
Date: Jan 05 '21
Time: 11:16pm
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
