Downshift at stoplight.
Postby jflynn [OP] » December 30th 2011, 3:18pm
Hello everyone. First post to this forum. Thanks to all who make it possible!
My van seems to downshift when i come to a full stop at a traffic light. I drove an 87 c1500 that use to do it and was told the trans, spline yoke was binding in the trans. A little grease fixed the problem. Is this a commom problem with GM vehciles/trans, or could i have other problems? Again Thanks for the help.
jflynn
Years of Membership: jflynn has been a member for 9 full yearsjflynn has been a member for 9 full yearsjflynn has been a member for 9 full yearsjflynn has been a member for 9 full yearsjflynn has been a member for 9 full yearsjflynn has been a member for 9 full yearsjflynn has been a member for 9 full yearsjflynn has been a member for 9 full yearsjflynn has been a member for 9 full years
Extra Info: 4.3L RWD
Re: Downshift at stoplight.
Postby Phantom » December 30th 2011, 3:34pm
Welcome...Can you be more specific.. trans is designed to downshift into first gear when rpm gets low enough ,,,the grease may have been for the U joints , and U joints and trans splines are common on many types of vehicles
Phantom
Firing on 7 Cylinders (L4)
Postby 93xtmoney » December 30th 2011, 3:39pm
Welcome aboard
93 Safari XT awd slt with the GMC touring package a.k.a. Money Machine
5000K foglights, type R headlights 7000K, clear corners, APC black euro tail lights,
93xtmoney
Years of Membership: 93xtmoney has been a member for 10 full years93xtmoney has been a member for 10 full years93xtmoney has been a member for 10 full years93xtmoney has been a member for 10 full years93xtmoney has been a member for 10 full years93xtmoney has been a member for 10 full years93xtmoney has been a member for 10 full years93xtmoney has been a member for 10 full years93xtmoney has been a member for 10 full years93xtmoney has been a member for 10 full years
Topics: 25
Extra Info: Xt AWD
Postby jflynn [OP] » December 30th 2011, 4:51pm
I was told that the splines in trans, output shaft get dry and cause the yoke to bind and not slide on the shaft. Giving the impression that the trans is shifting when the load is off the driveshaft (at a stop light) and the yoke pops back in the transmission. Apparetly the drive shaft slides in and out of the transmission as engine load is sent to the rear axlle while driving. I could be wrong. I do have a high idle which i think is from a vacum leak from the line that feeds the ac system. Got to pull the doghouse this weekend.
jflynn
Postby Mr_Bowtie » December 30th 2011, 4:55pm
If its idling higher then it might be that down shifting may just be more apparent to you now. Check your tranny fluid and fix the possible vacuum leak.
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby jflynn [OP] » December 30th 2011, 4:58pm
Will do. Thanks
jflynn
Postby Phantom » December 30th 2011, 5:35pm
Here are some pics to help you see how they look the spline slides in the trans trans and is lubed by trans fluid not grease ,, but the U joints , the things that look like a cross or plus sign are the
u- joints and have grease fittings to accept grease ,when it is all bolted together the splines should not move in or out , maybe what you are feeling is dry u-joints that move up and down slightly , and agree with previous post , you can either lube them your self or just go to any oil change shop and ask for a grease lube job , should only be a few bucks and they will lube everything that needs grease
trans spline.JPG (19.96 KiB) Viewed 721 times
trans spline 2.JPG (22.63 KiB) Viewed 721 times
u joints and driveshaft.png (6.31 KiB) Viewed 721 times
Phantom
Postby jflynn [OP] » December 30th 2011, 8:38pm
Ok. Didnt think about trans oil being back there on the output shaft. After all thats why theres a seal there. Just took somebodys :screaming: word for it. Will check this weekend a see if the u jnts have fittings on them. See what happens. Thanks
jflynn
Return to Automatic
It is currently April 20th 2021, 6:19pm
Automatic Forum
Bikley
in Automatic
Date: Mar 29 '21
Time: 5:42am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:49am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:42am
in Automatic
Date: Mar 01 '21
Time: 7:14pm
AngryPunk
in Automatic
Date: Feb 18 '21
Time: 11:47pm
