Transmission not shifting out of second
Postby reddsand [OP] » January 19th 2012, 4:04pm
Hope you guys can help me out with this. 1987 Chevy Astro. Supposedly 700r4 tramsmission. Purchased about 6 months ago. Will not shift out of 2nd. I checked the fluid and it was low. Topped off and test drove it. Still will not shift. Dropped the pan to change strainer. Fluid was extremely dirty but no burned smell. Did see a few metal shavings. Test drove again. Still not shifting. Not even manually. Did notice that the speedometer does not move until it has shifted the first time. Could this be related? Any ideas? Haven't been inside a transmission other than changing strainers before but not afraid to.
reddsand
Years of Membership: reddsand has been a member for 8 full yearsreddsand has been a member for 8 full yearsreddsand has been a member for 8 full yearsreddsand has been a member for 8 full yearsreddsand has been a member for 8 full yearsreddsand has been a member for 8 full yearsreddsand has been a member for 8 full yearsreddsand has been a member for 8 full years
Van Model Year: 1987
Extra Info: 4.3L V6
  • number 2 on automatic transmission shifter
    by Olivier02 » June 13th 2020, 9:22pm in Automatic
    Last post by SportsBoy View the latest post
    June 14th 2020, 12:51am
  • Best place to go for a transmission service?
    by pottsitive » July 22nd 2020, 2:39pm in Automatic
    Last post by Wiley View the latest post
    July 22nd 2020, 5:03pm
    9
    77
    December 2nd 2020, 12:49pm
Re: Transmission not shifting out of second
Postby chevymaher » January 20th 2012, 12:13am
Low on fluid and no high gear.Not a good sign.Probably burned up the clutches in the tranny.On your year tranny the speedo should be gear and cable driven.Not related to the non-shifting issue.But my 90 astro had a completely electronic 700R4 in it.You can tell by looking to see if you have a mechanical cable for shifting and speedo cable.Or just wires.
Return to Automatic
It is currently December 2nd 2020, 12:49pm
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
