Is this suppose to have a plug in it?
Postby Birdshake [OP] » July 5th 2019, 5:06am
Looked under my van and saw a dark spot thought it might be a leak till I looked closer.
Is this the right part for it?
https://www.rockauto.com/en/catalog/chevrolet,2005,astro,4.3l+v6,1430962,transmission-automatic,torque+converter+housing+plug,17904
Thanks
2005 4WD Astro Cargo
NP236 3.73 Eaton Posi
S10 HD Springs 3" blocks
245/75/16 BFG KO2
KYB Monomax
Birdshake
Years of Membership: Birdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full years
Topics: 10
Images: 26
Extra Info: 4.3 AWD
  • Question What brand of drain plug kit do you use?
    by gavio » July 22nd 2020, 4:19am in Automatic
    Last post by AstroOafAdventurerAstroOafAdventurer is online! View the latest post
    September 18th 2020, 3:29am
    40
    October 28th 2020, 11:45pm
Re: Is this suppose to have a plug in it?
Postby Astrofarian » July 5th 2019, 5:24am
Yes, there's supposed to be a plug in it and yes, the one you linked to looks right. Measure the hole; the listing says the plug is 28mm in diameter. The hole should be close to that size for this plug to fit properly.
-M!ke-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby Birdshake [OP] » July 5th 2019, 4:34pm
I measured it this morning and it was about 55mm so I don't think that plug will be big enough.
I did find this one I think will work and my local GM parts counter is ordering it in to pick up today.
Thanks!
245/75/16 BFG KO2
KYB Monomax
Birdshake
Topics: 10
Images: 26
Extra Info: 4.3 AWD
Postby Astrofarian » July 6th 2019, 2:35am
The 28mm plug might be for a "Timing Hole"? Long weekend, otherwise someone with a better idea of how to help you would have surely jumped in by now. Hope the plug they ordered works out for you!
-M!ke-
Astrofarian
Alias (AKA): M!ke
Return to Automatic
It is currently October 28th 2020, 11:45pm
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
MmusicmanMmusicman is online!
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
