PO757 Code selinoid 'B" malfuncion
Postby Rinny [OP] » September 10th 2019, 2:42am
So I am running the beaches, lots of soft sand, have never had to air down with lo range and posi Front and rear difs. Running a NP236 with an alternate shift pattern for 4lo, SES light comes on today and it seems like the trans is slipping. Clear the code and it is fine, Put it in 4 lo and the light comes back on. Take It out of 4lo and switch to 2H, switch To he standard shift pattern and it seems like the trans is slipping again, Clear the code and all is well in 2H. Does anyone have input on if it is the solenoid, or faulty infernal wiring for he solenoid?
03Astro AWD/4WD
TorsenDiffs,3:73'S,VettServo
NP236TC
Dual Piston Rear Calipers
GY DTrac 235/85/R16
ARB &/Custom bumpers
2x6x1/4 Rockrails
Rinny
Years of Membership: Rinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full years
Images: 6
Extra Info: 5.7L NP236
  • P0894 Code
    by Lowcountry » September 16th 2020, 4:52am in Automatic
    Last post by Lowcountry View the latest post
    September 18th 2020, 7:40pm
  • P2761 code keeps popping up
    by offctr » October 27th 2020, 4:17am in Automatic
    October 27th 2020, 1:53pm
    26
    January 17th 2021, 10:23am
Re: PO757 Code selinoid 'B" malfuncion
Postby Rinny [OP] » September 10th 2019, 2:59am
Going to have to drop the pan either way so I will do the filter, and why not test for continuity and replace the solenoids, rite?
03Astro AWD/4WD
NP236TC
GY DTrac 235/85/R16
2x6x1/4 Rockrails
Rinny
Images: 6
Postby albrow100 » September 10th 2019, 4:23am
I’d replace the solenoid and the internal harness while your in there
Both are cheap enough
albrow100
Topics: 30
Images: 18
Extra Info: awd
Postby Rinny [OP] » September 10th 2019, 11:23am
albrow100 wrote:I’d replace the solenoid and the internal harness while your in there
Thanks. did no realize the harness is a plug and play, and that could be the problem seeing the scanner keeps bouncing back between reading a code and no codes.
03Astro AWD/4WD
NP236TC
GY DTrac 235/85/R16
2x6x1/4 Rockrails
Rinny
Images: 6
Postby Rinny [OP] » September 10th 2019, 11:27pm
I am also going o have the tranny flushed rite b4 I drop the pan and change the filter. Running Valvoline max life synthetic.
03Astro AWD/4WD
NP236TC
GY DTrac 235/85/R16
2x6x1/4 Rockrails
Rinny
Images: 6
Return to Automatic
It is currently January 17th 2021, 10:23am
Automatic Forum
Youngblood
in Automatic
Date: Jan 15 '21
Time: 1:24am
allenstoltzfus
in Automatic
Date: Jan 14 '21
Time: 7:36pm
runawayjim
in Automatic
Date: Jan 07 '21
Time: 2:09pm
Attached by: SportsBoy
SportsBoy
in Automatic
Date: Jan 05 '21
Time: 11:16pm
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
Users browsing this forum: BikleyBikley is online! and 9 guests
