Transmission leak.
Transmission leak.
Postby Horrible_North [OP] » February 28th 2020, 11:52pm
So I just changed out my transmission mount on my 94 AWD astro. Afterwards I drove it a few miles and pulled back into the shop. Got under it cuz I could hear a clicking and wanted to put eyes on the noise. Everything looked good so I crawled back out. It was sitting at idle for a few minutes when I noticed smoke coming from underneath. So I started to crawl back under and immediately saw tranny fluid pissing out onto the exhaust. After shutting it off and doing some looking around and cleaning up I was able to spot where the leak is coming from. It's from right above the starter. There is also a big crack in the case that isn't leaking anything. I'm thinking I may have caused the crack while changing the mount cuz it looks pretty new. The starter is also having a hard time starting it now as well. Any ideas on what you guys think may have happened would be super helpful. I'm guessing I will be putting it on a trailer and taking it into a shop but I wanted y'all's input first. I'll include a picture of the crack. It's at the front of the tranny by the oil pan.
Horrible_North
Extra Info: LT AWD
  • Transmission oil cooler leaks
    by Rod's Trucks » April 14th 2020, 8:20pm in Automatic
    April 22nd 2020, 2:03am
  • 1999 GMC Yukon Transmission fit inside of Astro/Safari?
    by gman » April 22nd 2020, 9:29pm in Automatic
    April 25th 2020, 6:06pm
    7
    28
    September 23rd 2020, 4:22pm
Re: Transmission leak.
Postby CopperFiremistCopperFiremist is online! » February 29th 2020, 1:22am
My guess is the Transmission cooler line got tweaked just enough to fail. I know on the later vans they would rub through on the oil pan but your setup is a little different.
Pullin The Pass
Firing on 1 Cylinder (L2)
Topics: 24
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Postby MechBob » February 29th 2020, 5:34pm
I think you may have busted/cracked your transmission case, if things shifted enough to bust the flex plate cover like that. Good luck.
MechBob
Blue Status (L2)
Blue Status (L2)
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Return to Automatic
It is currently September 23rd 2020, 4:22pm
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
