94 Safari AWD 4l60e first time rebuild
Postby Bikley [OP] » May 4th 2020, 2:50am
I'm going to start with a box of parts and a plan.
It's going to be a little while before I can put a wrench to it because we have a Blazer to get running and a F(w)ord that needs to be tagged before I can take the van out of commission. In the meantime I'll inventory the parts and tools and post that next.
Bikley
Years of Membership: Bikley has been a member for 2 full yearsBikley has been a member for 2 full years
Topics: 19
Extra Info: AWD Vin W
  • Strange, one time shudder after very long uphill drive.
    by gman » June 25th 2020, 9:09am in Automatic
    Last post by gman View the latest post
    June 27th 2020, 8:11pm
  • 1997 AWD - can you assist re my trans/ xfer case
    by swing » October 26th 2020, 6:01am in Automatic
    October 29th 2020, 10:44pm
    62
    November 29th 2020, 9:17pm
Re: 94 Safari AWD 4l60e first time rebuild
Postby markmitch » May 4th 2020, 3:00am
I recommend this:
ATSG 4L60E Rebuild Manual Automatic Transmission Service Overhaul Techtran Book 4L65E 4L70E 4L75E
Firing on 6 Cylinders (L6)
Topics: 615
Images: 20
Extra Info: RS V8
Postby Bikley [OP] » May 4th 2020, 3:16am
Thanks Mark that will definitely come in handy.
Bikley
Topics: 19
Postby Bikley [OP] » July 27th 2020, 3:45am
Ok it's been awhile but I've finally acquired all the parts and tools to proceed except the torque converter.
When I narrowed it down to the ATC Pro King GM35CW it said for ACCC only system but mine is a 94 and after searching ACCC, it didn't start until 96.
I would hate to put all this time and money in and burn it all up with the wrong torque converter because of a generic listing.
Bikley
Topics: 19
Postby chucksurette » July 27th 2020, 10:07am
Not sure about your torque converter.
Have you watched these videos? A very detailed teardown & rebuild series ( it's long ) from Transmission Bench.
https://youtu.be/SK84Qy_Vu_E
Good luck with the rebuild.
The machine that we built
would never save us.
That's what they say....
chucksurette
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: chucksurette has been a member for 1 full year
Topics: 7
Images: 9
Extra Info: RWD
Postby Wiley » July 27th 2020, 4:11pm
chucksurette wrote:Not sure about your torque converter.
Those look really good, I was going to save them to my computer, but then I saw their channel did not have a playlist. But no problem, I found them, for some reason it is under a different set of names, but it appears this is the entire series you posted up:
https://www.youtube.com/playlist?list=PLAQ57yDBzk8Lfv8WpqndwwQzhQiEwION6
2guys1truck.com: 2004 AWD Chevy Astro from California to Colombia!
Wiley
Years of Membership: Wiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full years
Topics: 7
Extra Info: AWD 2 inch Lift
Postby Bikley [OP] » July 28th 2020, 2:45am
Thanks. I actually bought my kit from Transmission Bench and it came with the videos on a thumb drive but I have watched them on YouTube. They are really good.
Bikley
Topics: 19
Postby Bikley [OP] » July 28th 2020, 7:28pm
Ok, I found the correct torque converter. It's a Pro King #GM18A from Advance. The ones listed were wrong so I called Pro King tech support and they gave me the correct part number. Yay!
Bikley
Topics: 19
Postby Ironsides » October 9th 2020, 12:02pm
I just went through the same thing, I'm researching it now. GM35CW vs GM90.
Good luck with your rebuild.
Ironsides
Years of Membership: Ironsides has been a member for 5 full yearsIronsides has been a member for 5 full yearsIronsides has been a member for 5 full yearsIronsides has been a member for 5 full yearsIronsides has been a member for 5 full years
Topics: 5
Van Model Year: 2001
Extra Info: RWD Custom HD
Return to Automatic
It is currently November 29th 2020, 9:17pm
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
MmusicmanMmusicman is online!
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
