number 2 on automatic transmission shifter
Postby Olivier02 [OP] » June 13th 2020, 9:22pm
Hi ! I have a gmc safari 2005 SLT AWD 4.3 Automatic and i was wondering if it was normal that if i put the shifter on the number 2, it seems to start with the second gear and not with the first one. If i put it on the number 1, it will stay on the first gear ; on number 3, it will stop at the third speed, but i was guessing that on the number 2 it should go on the first gear and the second.
i don't know if it's clear but thanks a lot !
Sans titre.png (195.19 KiB) Viewed 500 times
Olivier02
Alias (AKA): Olivier
Extra Info: SLT AWD 4.3L
  • GEAR SHIFTER STUCK IN PARK.
    by huddy » October 18th 2020, 2:04pm in Automatic
    October 22nd 2020, 7:30pm
  • Where to get 2005 AWD shifter cable ?
    by astrofinland » January 5th 2021, 4:50pm in Automatic
    Last post by astrofinland View the latest post
    January 7th 2021, 3:01pm
    28
    January 24th 2021, 9:58pm
Re: number 2 on automatic transmission shifter
Postby Leeann_93 » June 13th 2020, 9:35pm
Ummmmm....that's how it's supposed to work.
1 means first gear
2 means second gear
3 means third gear and also means drive, so 1-3 but no overdrive
D means all gears, including overdrive
N means neutral
R means reverse
P means park.
Postby markmitch » June 13th 2020, 9:59pm
I must agree with LeeAnn
Firing on 7 Cylinders (L6)
Topics: 624
Images: 20
Extra Info: RS V8 AWD
Postby MechBob » June 13th 2020, 11:48pm
Starting off in 2nd gear used to be a big thing, for when you are stuck.A slower start off, less chance of tires spinning.I haven't kept up on the newest stuff, but this feature will be gone soon.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby SportsBoy » June 14th 2020, 12:51am
I knew what 3 and 1 did, but had never used 2 when starting from a start actually, so glad I saw this - good to know!
SportsBoy
Topics: 23
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Return to Automatic
It is currently January 24th 2021, 9:58pm
Automatic Forum
Youngblood
in Automatic
Date: Jan 15 '21
Time: 1:24am
allenstoltzfus
in Automatic
Date: Jan 14 '21
Time: 7:36pm
runawayjim
in Automatic
Date: Jan 07 '21
Time: 2:09pm
Attached by: SportsBoy
SportsBoy
in Automatic
Date: Jan 05 '21
Time: 11:16pm
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
