Question What brand of drain plug kit do you use?
Postby gavio [OP] » July 22nd 2020, 4:19am
I can find about a jillion posts on here saying "install a drain plug when you have the tranny pan off", which sounds great and I'm all in favor, but can't find any references to which brand of drain plug kit works without leaking.....
This will be a no-weld situation, and looking at the reviews, it seems like most brands have substantial complaints about them leaking, including Dorman.... What gives? Is there a brand that has good odds of not leaking?
There's nothing wrong with my pan, so I'd just as soon not have to replace it, but I do want that drain....
Any thoughts?
gavio
Topics: 77
Images: 4
  • Which Transgo shift kit do I need? And which extras?
    by gavio » June 27th 2020, 4:04pm in Automatic
    Last post by gavio View the latest post
    June 28th 2020, 12:12am
  • Flush or drain & fill?
    by AstroOafAdventurer » August 12th 2020, 8:29pm in Automatic
    Last post by AstroOafAdventurer View the latest post
    September 18th 2020, 8:19pm
    23
    September 26th 2020, 10:33pm
Re: Question What brand of drain plug kit do you use?
Postby MechBob » July 22nd 2020, 1:09pm
Never used one that I did not weld in, but if I was, I would jut use the Dorman one.
MechBob
Blue Status (L2)
Blue Status (L2)
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby Bossman » July 22nd 2020, 6:43pm
I use a Dorman 265-811 Transmission Oil Pan. Amazon $40.99.
2 years on my 05 and has never leaked. I have pulled the plug 3 times and always seals tight.
No welding in an aftermarket plug. Worth the $$ IMO
Mike
Bossman
Years of Membership: Bossman has been a member for 2 full yearsBossman has been a member for 2 full years
Extra Info: RWD Cargo
Postby Leeann_93 » July 22nd 2020, 10:11pm
I've used both the B&M drain plug kit and the Superior automatic transmission drain plug kit and neither has ever leaked.
Superior:
https://www.oregonperformancetransmissi ... -K032.html
B&M:
https://www.amazon.com/80250-Automatic- ... B00029WR78
We use Loctite to hold the inside and outside piece together, then thread sealant on the actual drain plug (same stuff to use on the transfer case drain plug and fill and the differential drain plug (front diff on an AWD) and both fill plugs.
Or you can buy a Dorman pan with drain plug installed already:
https://www.amazon.com/dp/B002U6ELS4/re ... automotive
Postby gavio [OP] » July 22nd 2020, 11:36pm
Thank you for the responses, I appreciate the insight....
I have the Dorman pan in my back pocket as a plan B, I suppose, but it kinda rankles me to replace a perfectly good pan.... I'm glad to know some of the drain kits don't leak, or at least have the potential to not leak....
Leann, did you use the sealing washers that came with those B&M and Superior kits, or did you replace them with copper washers or some such?
gavio
Topics: 77
Images: 4
Postby Leeann_93 » July 23rd 2020, 12:12am
gavio wrote:Thank you for the responses, I appreciate the insight....
We used only what came with the kits, except for the plumbing goop (permatex jar with brush on the cap) on the actual plug.
Postby SportsBoy » July 23rd 2020, 12:18am
I used the B&M one Leeann linked - I used the nylon washers and totally smooshed them when tightening them down - next time I have the pan down I'll use copper.
No leaks that I'm aware of though - been a couple years.
SportsBoy
Topics: 18
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby gavio [OP] » July 23rd 2020, 3:05pm
Thank you, that's helpful to know....
gavio
Topics: 77
Images: 4
Postby Mr_Roboto » July 23rd 2020, 3:56pm
Never had any luck with these. I would use one in an OEM pan that came with it and just take the bath otherwise as much as I hate to say that. Even the aftermarket pan I bought with one in it drips.
Mr_Roboto
Firing on 1 Cylinder (L2)
Years of Membership: Mr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full years
Topics: 51
Postby AstroOafAdventurer » September 18th 2020, 3:29am
Will the Doorman pan fit my 97?
Amazon says no...
Please please say yes!
97 Astro Conversion Van 62k miles
AstroOafAdventurer
Topics: 23
Alias (AKA): Thorsteenster
Return to Automatic
It is currently September 26th 2020, 10:33pm
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
