'87 700r4 upgrade to '96 4L60E
Postby WDMICKJR [OP] » September 7th 2008, 4:36pm
i bring this question to you guys whom have done such before and whom are more in-depth in such matters as i...
i do not have all the parts here with me right now yet i have some questions.
i can obtain a '96 4L60E trans for $100 and i can have it rebuilt for $75, but..is this what i want to do???
I have a '87 astro sport with a '96 roadmaster LT1 [staggered roller rockers; 1.5" on the Int and 1.6" on the Ext, for torque (got to get the old out before you can put the new in)]. I want the ECM/PCM to work at doing what it does.
My delimma..i want the speedo in the original van to work with my new trans ..if i get it.
can i swap the old tailshft and install on the new trans for correct cable driven speedo or does the pcm/ecm also take info from the digital signal for efficency too?
like i said i dont have the trans yet...so i dont know...do you? and do you know what i am talking about?
SOLD 92 Astro CS with 95 4bolt 355 LT1, hand ported *374s & intake (David Vizard tech), EFI 24x, 211/219*, 1.94/1.6" 1.7"roller rockers .574"/.583", shift kit & corvette servo, G80, GT4, 255/70-15s, 2001LS1pcm; aka fAstro
WDMICKJR
Years of Membership: WDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full yearsWDMICKJR has been a member for 12 full years
Topics: 27
Alias (AKA): Billy
Extra Info: 94 LT1
Re: '87 700r4 upgrade to '96 4L60E
Postby WDMICKJR [OP] » September 7th 2008, 11:08pm
i have collected this info and shall share..
1996 4L60E has 4 bolt tail shaft, '97 and above 4L60E have 6 bolt tail shaft. the 700r4 has a 4 bolt tail shaft.
hmmm you would thunk that one could put a 700r4 manual cable driven tail shaft on a '96 4L60e trans.
now comes another dilemma...
what can one do about the VSS on the 4L60E? is this going to be a problem with the PCM/ECM? the plastic gears for the speedo cable in the tail shaft are at Raptor, if you have aftermarket road huggers.
WDMICKJR
Topics: 27
Alias (AKA): Billy
Extra Info: 94 LT1
Postby WDMICKJR [OP] » September 8th 2008, 12:25am
here is a lot of help...and i have answered my own questions. yet i will post to save someone some trouble if they ever have the same application:
http://www.jagsthatrun.com/V8-chapters/V8-tpi-Speed-Sensors.pdf
this has answered some questions about earlier manual cable speedo when your trans using VSS (instead of closed loop) to help yout LT1 or TBI computer controlled PCM/ECM engine trans package run like the factory intended.
sorry about the duplicate posts of same topic. the moderators of astrosafari.com may want to fix my error.
happy motoring..your mileage may vary
WDMICKJR
Topics: 27
Alias (AKA): Billy
Extra Info: 94 LT1
Return to Automatic
It is currently January 24th 2021, 11:14pm
Automatic Forum
Youngblood
in Automatic
Date: Jan 15 '21
Time: 1:24am
allenstoltzfus
in Automatic
Date: Jan 14 '21
Time: 7:36pm
runawayjim
in Automatic
Date: Jan 07 '21
Time: 2:09pm
Attached by: SportsBoy
SportsBoy
in Automatic
Date: Jan 05 '21
Time: 11:16pm
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
