P2761 code keeps popping up
Postby offctr [OP] » October 27th 2020, 4:17am
Have an 04 AWD that keeps popping a p2761 code TCC control solenoid circuit,aside from the solenoid and wiring harness in the pan --all the solenoids and wiring in the pan was changed due to damage to the clips and I wanted to eliminate that as a cause. Other than that it drives fine no weird shifts of slippage BUT the CEL will start to flash if you accelerate hard. Even with the engine not running the code will come right back if cleared. What should I be looking for at this point..
offctr
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: offctr has been a member for 6 full yearsoffctr has been a member for 6 full yearsoffctr has been a member for 6 full yearsoffctr has been a member for 6 full yearsoffctr has been a member for 6 full yearsoffctr has been a member for 6 full years
Topics: 9
  • P0894 Code
    by Lowcountry » September 16th 2020, 4:52am in Automatic
    Last post by Lowcountry View the latest post
    September 18th 2020, 7:40pm
    February 28th 2021, 4:41pm
Re: P2761 code keeps popping up
Postby AstroWill » October 27th 2020, 1:53pm
An actively flashing CES light indicates a misfire.
Your code sounds like a poor/intermittent connection somewhere along the circuit.
Images: 472
Return to Automatic
It is currently February 28th 2021, 4:41pm
Automatic Forum
AngryPunk
in Automatic
Date: Feb 18 '21
Time: 11:47pm
Youngblood
in Automatic
Date: Jan 15 '21
Time: 1:24am
allenstoltzfus
in Automatic
Date: Jan 14 '21
Time: 7:36pm
runawayjim
in Automatic
Date: Jan 07 '21
Time: 2:09pm
Attached by: SportsBoy
SportsBoy
in Automatic
Date: Jan 05 '21
Time: 11:16pm
