Solenoid B wiring not grounded, what next?
Postby runawayjim [OP] » January 6th 2021, 4:19am
Just purchased a 2003 Safari SLT, AWD and am excited to get it running well. First up was a bad solenoid B code (both P0756 and P0758), and driving that seemed to go along with a faulty solenoid. Dropped the pan to replace both solenoids, but they both work fine. However, the wiring to solenoid B appears to not grounded when checked. What should my next step be? Look into PCM, try to access external harness and test pin S (is it even possible to get a hold of this harness without dropping the tranny a bit?
Called it a night, but any advice on how to proceed would be helpful. Excited to finally join the Astro/Safari world and grateful for this forum. I really don't know anything about fixing cars but excited for many projects ahead!
runawayjim
Extra Info: SLT AWD
Re: Solenoid B wiring not grounded, what next?
Postby Rod's Trucks » January 6th 2021, 5:39am
Runawayjim,
I cannot help with that specific question, but want to welcome you to the madness.
I am sure there will be others who will know exactly what you need to know. Whether it is what you wantto hear, is another thing entirely.
Pictures are always welcome.
You might consider putting you general location in your profile.
You never know who might offer to help, if they know they are reasonably close.
Rod J
Issaquah, WA
Rod's Trucks
Topics: 32
Images: 55
Alias (AKA): Rod and/or WE7X
Postby runawayjim [OP] » January 6th 2021, 6:41am
Rod's Trucks wrote:Runawayjim,
Rod J
Issaquah, WA
I will update, as I'm over in Yakima, not too far from you!
runawayjim
Extra Info: SLT AWD
Postby dcsleeper » January 6th 2021, 8:15am
I just want you to be aware that these vehicles use lots of common parts.
And Amazon has been a good source for me.
It looks like this is everything electromechanical inside the tranny. Verify if you decide to get this.
https://smile.amazon.com/4L60E-Piece-Solenoid-Harness-Manifold/dp/B077Y2YLRD/ref=sr_1_8?dchild=1&keywords=solenoid+and+wiring+4l60&qid=1609917078&sr=8-8
Profile | Edit signature
dcsleeper
Topics: 20
Images: 77
Alias (AKA): DC
Postby runawayjim [OP] » January 7th 2021, 2:10pm
Turns out it was a bad wire behind the heat shield. Maybe I should've taken the heat shield off and looked before dropping the pan. Just excited to have this thing up and running well at the moment!
runawayjim
Extra Info: SLT AWD
Postby sixsix » January 7th 2021, 9:41pm
runawayjim wrote:Turns out it was a bad wire behind the heat shield.
Yup, the Olde Heat Shield area...
So only CAL, ILL & NY Elects??
Firing on 7 Cylinders (L5)
Topics: 38
Images: 1320
Return to Automatic
It is currently March 7th 2021, 4:33pm
Automatic Forum
95AstroLT
in Automatic
Time: 3:49am
95AstroLT
in Automatic
Time: 3:42am
in Automatic
Date: Mar 01 '21
Time: 7:14pm
AngryPunk
in Automatic
Date: Feb 18 '21
Time: 11:47pm
Youngblood
in Automatic
Date: Jan 15 '21
Time: 1:24am
