Can I switch to deep tranny pan from shallow?
Postby the_bruce [OP] » May 2nd 2021, 10:31pm
97 Safari RWD - 100K miles
I am doing a transmission fluid change (not the flush option, did not want to dig into the radiator connections). I installed a drain plug in the pan, but upon reassembly it will not let the pan seat correctly. Stupid me put the drain in a bad place and the inside bolt is hitting something.
So, I can either try again with a new shallow pan trying to put the drain in an acceptable place and hope it works, or I was thinking of getting a deep pan and filter to allow more room. I think both the shallow and deep pans have 16 bolts, and gaskets look the same so as long as I got the correct filter I think it would work. Anyone done this?
Also, one of the short bolts sheared off while taking off the pan :banghead: I was going to put together once I get the drain location figured out and see if it leaked once all the bolts are torqued correctly. Anyone ever remove a broken tranny pan bolt?
Everything seems to take me three times as long as I think it should and there is always some SNAFU that pops up. :whack:
Thank you,
Bruce
the_bruce
Years of Membership: the_bruce has been a member for 3 full yearsthe_bruce has been a member for 3 full yearsthe_bruce has been a member for 3 full years
Alias (AKA): Andy
Extra Info: SLE 4.3L V6 RWD
  • Changing tranny fluid on low miles safari
    by JusticeIroquois » January 3rd 2021, 6:26pm in Automatic
    Last post by mdconvert View the latest post
    January 5th 2021, 1:09pm
    9
    71
    May 17th 2021, 3:49am
Re: Can I switch to deep tranny pan from shallow?
Postby Bigforkg » May 3rd 2021, 2:54am
You could go with a deep pan just make sure to get the filter for a deep pan. Here is one with a drain already. DOUBLE CHECK ME. https://www.amazon.com/Assault-Racing-P ... B01LX45FC5
Bigforkg
Years of Membership: Bigforkg has been a member for 1 full year
Topics: 9
Images: 2
Extra Info: V8 4x4 246Tcase
Postby AstroWill » May 3rd 2021, 11:47pm
Pans bolt up the same, just change to the proper filter.
Do you have a picture of your pan and the new drain that you installed, so others can see where not to put the drain?
As far as the bolt, drill it, start with a small pilot and make sure it's centered and straight so you don't damage the threads. Otherwise if there is enough to weld a nut to the remaining bolt, you can use that to remove it.
Topics: 109
Images: 473
Postby AstroOafAdventurer » May 4th 2021, 4:12am
I did this a few months back on my then new to me Astro while changing the trans fluid for the first time.
I bought a Dorman deep pan with the plug already in it and matching filter.
Easy peasy.
https://smile.amazon.com/gp/product/B00 ... UTF8&psc=1
And this filter:
97 Astrofari Conversion Van 62k 64k miles, 65k miles
AstroOafAdventurer
Topics: 43
Alias (AKA): Thorsteenster
Extra Info: RWD GMC grille
Postby SportsBoy » May 4th 2021, 1:07pm
Deep pan works fine, just get a deep filter.
I took mine off a tahoe trans I think.
It's too bad you drilled the wrong spot on the original though - did you not put it in the circular depression?
SportsBoy
Topics: 24
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby the_bruce [OP] » May 8th 2021, 1:13am
AstroWill wrote:Pans bolt up the same, just change to the proper filter.
Thank you, that sounds like a pan plan. And the bolt sheared off just a tad above the bottom of the tranny pan mating surface. I have seen a video where a guy inserted a small section of copper line to shield the threads and he used a mig welder to tack on little bits until it was out of the hole, then welded an old screw driver to the weld. Could do a nut too. Came out easy for him, but I am used to having more trouble with this type of thing.
I was going to try a screw extractor but drilling in the tranny makes me extremely nervous. Would take half a second to go very bad if I got into the threads.
Bruce
the_bruce
Alias (AKA): Andy
Postby the_bruce [OP] » May 8th 2021, 1:14am
AstroOafAdventurer wrote:I did this a few months back on my then new to me Astro while changing the trans fluid for the first time.
Easy peasy.
And this filter:
Great info, :ty:
the_bruce
Alias (AKA): Andy
Postby the_bruce [OP] » May 8th 2021, 1:19am
SportsBoy wrote:Deep pan works fine, just get a deep filter.
The stock pan was one of the flat ones, no depression except a few lines where the magnet goes. I got ahead of myself installing the drain plug on a rainy day before I could pull the old pan off and get a good look for placement. Thought I'd have enough room on the rear corner of the pan, but au contraire.
I will take pictures of the badly placed drain plug so all can learn from my blunder.
Bruce
the_bruce
Alias (AKA): Andy
Postby SportsBoy » May 8th 2021, 3:29am
Bruce
Ah, gotcha - I couldn't remember what the original pan looked like
SportsBoy
Topics: 24
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby the_bruce [OP] » May 14th 2021, 9:40pm
:ty: Thanks for the tips! With my latest Amazon delivery I am now loaded for bear... I have got:
-deep pan filter
-Dorman deep pan w/drain pre-installed (quality seems good, drain plug assembly looks reasonably solid and has an aluminum crush washer included)
-new OEM pan bolts
-M8 x 1.25 thread tap in case the two bolt holes with galled threads give me any sass :whack:
-RIDGED screw extractor set for the broken bolt
-and, just in case the bolt extraction or thread chasing goes to hell in a handbasket, a helicoil kit.
Not messing around this time. This van WILL be on the road this weekend come hell or high water. :rockon:
Just in case the helicoil is necessary, does anyone have any tips for installing in aluminum? Some sites say use thread cutting oil, some say use special aluminum oil, some say don't use any at all in soft metals which concerns me a little.
-Bruce
the_bruce
Alias (AKA): Andy
Return to Automatic
It is currently May 17th 2021, 3:49am
Automatic Forum
fryaeggontheground
in Automatic
Date: May 05 '21
Time: 5:30pm
OldSchoolNoe
in Automatic
Date: May 03 '21
Time: 7:56pm
Bikley
in Automatic
Date: Mar 29 '21
Time: 5:42am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:49am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:42am
