tranny return line/cooler install
Postby chris in b'ham [OP] » April 17th 2012, 5:17am
started my tranny cooler install today (2005 astro) and i come up against the fitting connecting the return line to the radiator. i have not seen this type of fitting before. what is the trick to it? the haynes manual is useless as usual in explaining it. i am installing the hayden rig and i bought the install kit with the new fittings.
thanks for any suggestions.
best to all, chris
chris in b'ham
Years of Membership: chris in b'ham has been a member for 8 full yearschris in b'ham has been a member for 8 full yearschris in b'ham has been a member for 8 full yearschris in b'ham has been a member for 8 full yearschris in b'ham has been a member for 8 full yearschris in b'ham has been a member for 8 full yearschris in b'ham has been a member for 8 full yearschris in b'ham has been a member for 8 full years
  • Tranny cooler install help
    by Chunkstyle » August 11th 2020, 11:13pm in Automatic
    August 14th 2020, 12:06am
  • 07 Colorado tranny in 00 Astro
    by dasvigo » July 5th 2020, 4:56am in Automatic
    July 6th 2020, 11:18pm
    28
    October 21st 2020, 2:32am
Re: tranny return line/cooler install
Postby Corsemoto » April 17th 2012, 5:49am
There's a tiny retaining clip in the groove which keeps the line in the fitting on the radiator. Use a pick to work it out and the line just pulls out of the fitting. I prefer to replace the quick connect clips as they can distort, you can find them at the local auto parts place, like these: http://www.amazon.com/Dorman-800-801-Connector-Clips/dp/B000CIXMPK
Other than that the fittings just thread into the radiator.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby Phantom » April 17th 2012, 6:36am
This is what I prefer to use Hayden 390 fittings
Phantom
Firing on 7 Cylinders (L4)
Postby chris in b'ham [OP] » April 17th 2012, 10:33pm
thanks for the help. i see how it works. i did buy the hayden 390 adapters for the cooler install.
best to all, chris
chris in b'ham
Return to Automatic
It is currently October 21st 2020, 2:32am
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
