awd switch
awd switch
Postby gmcvanman [OP] » December 24th 2012, 8:50pm
i was plotting my van projects, at work when im bored i think bout hot rodding or customisizin vans , trucks e.x i was goin to get a 2.8l s10 fer scootin and then i thaught thats guna get mpg sure its quick sure but they made a turbo 2.8 thats better haha, so any ways i thaught bout all ya van buddies of mine that have the early awd with ft awd and idk if this will help but how bout wiring in a switch to open the awd circuit unless u turned it on? the people who have done a lot w awd or vans in general would know if this will work or not im still new i love my ol van and im here fer wisdom lol :banana:
1964
260k n counting, future LS3 mustang killer :-)
gmcvanman
Years of Membership: gmcvanman has been a member for 8 full yearsgmcvanman has been a member for 8 full yearsgmcvanman has been a member for 8 full yearsgmcvanman has been a member for 8 full yearsgmcvanman has been a member for 8 full yearsgmcvanman has been a member for 8 full yearsgmcvanman has been a member for 8 full yearsgmcvanman has been a member for 8 full years
Topics: 48
Images: 47
Alias (AKA): safariowner vanman
Extra Info: rwd 4.3l cargo van
  • Toggle switch torq conv. lockup PWM
    by M_a_t_t » August 21st 2020, 6:04pm in Automatic
    Last post by M_a_t_t View the latest post
    September 5th 2020, 10:36pm
  • 1997 AWD - can you assist re my trans/ xfer case
    by swing » October 26th 2020, 6:01am in Automatic
    October 29th 2020, 10:44pm
    33
    January 16th 2021, 9:21am
Re: awd switch
Postby jrsride2002 » February 21st 2013, 12:38am
I asked my machanic friend the same/similar question. He suggested swapping or figure in the Jimmy setup. He said a Jimmy has a button for 4x4 and some sort of a vacumm line. He would certainly know better then I would, so thats where I will be starting my searches, when I get some free time.... :banghead:
You might want to start your own searches there...
Just a thought,
~Junior
jrsride2002
Years of Membership: jrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full years
Topics: 37
Images: 21
Alias (AKA): Junior
Van Model Year: 2001
Extra Info: LS V6 RWD
Re: awd switch
Postby redfury » February 21st 2013, 3:37am
My AWD was swapped out for a 4x4 transfer case out of the S 10 line. I looked into the design quite a bit recently. While my front axle is engaged all the time, the transfer case only runs in 2wd until I command it to run in 4wHI or LO.
The S 10 platform uses a vacuum operated front axle disconnect. The transfer case has a 3 pronged vacuum switch that gets vacuum and runs two lines to operate the vacuum actuator. It simply uses a fork in the passenger side front axle that moves the engagement gear in and out of engagement. It also sends a signal to the controller that the axle is engaged or not.
Now, you can't go using 4wd on dry pavement this way as the transfer case binds up after a few miles, but if you opt to go up to the 4 button transfer case, it has a clutch system similar to the AWD case that allows full time 4wd. However, the 4 button requires wheel speed sensor input as well and probably would only really work well on the newest of our vans as far as wiring integration goes.
The axle could be converted to the S 10 style as the axle shafts are the same from what I remember reading, it's just a matter of wanting to do all the extra work or not. I don't think there'd be a significant gain from it. I could be wrong though, I'm new to all this drivetrain stuff and everything I've written here is knowledge gained only by reading and research and what I've experienced with my set up.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Re: awd switch
Postby Drummernaut » February 21st 2013, 1:22pm
gmcvanman wrote:i thaught bout all ya van buddies of mine that have the early awd with ft awd and idk if this will help but how bout wiring in a switch to open the awd circuit unless u turned it on? the people who have done a lot w awd or vans in general would know if this will work or not im still new i love my ol van and im here fer wisdom lol :banana:
From what I understand the early AWD(before 99) are mechanical with no wiring or electronics.
For 99 and up you could take the circuit I messed with here( viewtopic.php?f=70&t=17236 ) and modify it like in the picture below. I wanted an approach that would allow the electronic circuit to see a load no matter what. Either the load goes to the motor or to the dump resistor. I think this would be better than turning the whole electronic circuit on and off with a switch or by pulling the fuse. You would not have an AWD service light and you could use a lighted switch/push button mounted anywhere.
Components would be a 12VDC DPDT 20 amp relay and base $30+ from grainger. A switch/push button from car parts store and a 1 ohm 300W resistor. We have a few lying around at work but you can find them on Ebay.
1999 Astro LT AWD
MODS: Electric fan, Transmission cooler/fan, AWD engaged LED
Drummernaut
Years of Membership: Drummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full years
Topics: 9
Alias (AKA): Drummer From Hell
Extra Info: LT V6 AWD
Re: awd switch
Postby Drummernaut » February 21st 2013, 11:48pm
Drummernaut wrote: You would not have an AWD service light
I have been corrected, you will get DTC codes with too much of a slip difference as in doing donuts!!! Or driving in the snow with this switch enabled.
1999 Astro LT AWD
Drummernaut
Topics: 9
Return to Automatic
It is currently January 16th 2021, 9:21am
Automatic Forum
Youngblood
in Automatic
Time: 1:24am
allenstoltzfus
in Automatic
Date: Jan 14 '21
Time: 7:36pm
runawayjim
in Automatic
Date: Jan 07 '21
Time: 2:09pm
Attached by: SportsBoy
SportsBoy
in Automatic
Date: Jan 05 '21
Time: 11:16pm
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
