99 safari, AWD transfer case popping
Postby texaszero [OP] » February 26th 2013, 4:54am
well my van started popping from the drive line, as my band made it back to town from tour. i checked the you joints, they all seemed good, checked the rear end, it looked good. when i twisted the derive shaft back and forth i could tell it was coming from the transfer case. so i put it on jack stands and removed the drain plug, and hardly any oil came out. not good. the rear seal was leaking and it lost all the oil on the trip( i am assuming) .
my question is, can i just fill it back up with oil and drive it, or is there any thing in the transfer case that is now damaged? also how does the front shaft come out of the case?
the band will be hitting the road again soon and i gotta get this thing back purring like a kitten
thanks johnny
texaszero
Years of Membership: texaszero has been a member for 9 full yearstexaszero has been a member for 9 full yearstexaszero has been a member for 9 full yearstexaszero has been a member for 9 full yearstexaszero has been a member for 9 full yearstexaszero has been a member for 9 full yearstexaszero has been a member for 9 full yearstexaszero has been a member for 9 full yearstexaszero has been a member for 9 full years
  • P2761 code keeps popping up
    by offctr » October 27th 2020, 4:17am in Automatic
    October 27th 2020, 1:53pm
  • 1997 AWD - can you assist re my trans/ xfer case
    by swing » October 26th 2020, 6:01am in Automatic
    October 29th 2020, 10:44pm
    9
    30
    April 20th 2021, 11:55pm
Re: 99 safari, AWD transfer case popping
Postby thegreenmachine » February 26th 2013, 5:47pm
front shaft has four bolts on the f. diff side and it slides off the output shaft on the t.case side.
fill it up with 2 quarts of auto-trac II, and see what happens.........
"that looks legit"
95 AWD Safari money pit
thegreenmachine
Firing on 6 Cylinders (L2)
Years of Membership: thegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full years
Topics: 62
Alias (AKA): Shane a lane
Postby texaszero [OP] » February 27th 2013, 12:13am
it seems stuck, is the boot holding it on?
texaszero
Postby redfury » February 27th 2013, 4:06am
It should just slide out, you may have to "coax" it with a hammer. Chances are the lack of lubrication has it stuck. You will want to replace the leaking seal and fill it with new fluid. It's a gamble whether the transfer case will have survived or not. Chances are probably not on your side as it needs the fluid to lubricate the clutch pack with oil, and the clutch pack needs oil.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Return to Automatic
It is currently April 20th 2021, 11:55pm
Automatic Forum
Bikley
in Automatic
Date: Mar 29 '21
Time: 5:42am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:49am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:42am
in Automatic
Date: Mar 01 '21
Time: 7:14pm
AngryPunk
in Automatic
Date: Feb 18 '21
Time: 11:47pm
