1997 Safari Rear U joint bolts
Postby Hollywooonj [OP] » April 11th 2013, 9:42pm
1997 Safari Rear U joint bolts… MADNESS!!!!!~ What is the deal with the crummy 8mm bolts? Are they 8 mm? Cant find that answer anywhere, No help in the shop service manual. Every where you go they assume you get the bolts out and dont even mention them. Everyone says…"Remove the 4 bolts with a socket or wrench"( most good sockets do not fit in there). nothing fits but a small open end wrench that slips. Really do I really need to be told to remove the bolts, WOW ,, How about what tool before I crawl under the truck. Broke a small 5/16 wrench and now the 1/4 drive 8mm socket slips too. They dont look decayed. :confused:
searched for EVER for answers Never thought these would be so much trouble, We use to change them on the road when I was a kid on my friends off roadchevy truck,, 10 minutes with a 3/8 wrench ( i think) to remove bolts and large sockets and hammer to press new u joint, back on the trail in 15 minutes. Never thought I would be hung up from these damn bolts,, damn metric! No room to get a good strong socket or wrench in there . Do i need to spend $20 to get a impact socket from grainger that still may not fit in there THIS IS INSANE,
Hollywooonj
Years of Membership: Hollywooonj has been a member for 7 full yearsHollywooonj has been a member for 7 full yearsHollywooonj has been a member for 7 full yearsHollywooonj has been a member for 7 full yearsHollywooonj has been a member for 7 full yearsHollywooonj has been a member for 7 full yearsHollywooonj has been a member for 7 full years
Alias (AKA): Hollywood
Extra Info: SLE
Re: 1997 Safari Rear U joint bolts
Postby chevymaher » April 11th 2013, 9:48pm
They are tiny and I use a box end wrench on mine.
Postby sfeaver » April 11th 2013, 10:11pm
They are 5/16. Try a six-point socket, will grab better than 12-point if that is what you used.
Scott
sfeaver
Firing on 8 Cylinders (L1)
Topics: 29
Images: 21
Van Model Year: 2001
Extra Info: LT RWD 350ci V8
Postby Corsemoto » April 11th 2013, 10:38pm
Yeah, they are 5/16 though I've always used an 8mm box end wrench without an issue.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby 97cargocrawler » April 12th 2013, 12:01am
Yeah I was surprised to find they were Standard. I suppose it has something to do with the axle using Standard hardware as well. I found the 8mm was a bit loose and started to round the head of the bolts. A small box end wrench works unless you're anal (like me) and want to actually torque those bolts to spec instead of snapping them off. I ultimately used a 1/4" drive extension shaft with 5/16" socket and a drive adapter to my torque wrench. That works but you have to rotate the drive shaft in order to get to each bolt. Those bolts are as crappy as the strap they secure so I'd be very careful not to over tighten them.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby Corsemoto » April 12th 2013, 12:25am
Must be used to working on motorcycles with smaller fasteners/hardware often so not worried about damaging hardware. 8mm box end isn't loose for that hardware on my van, I just give them a little sharp crack to break loose and they come off easy. Lucky for me it's relatively rust/corrosion free I guess.
Cargo, you're right it's all standard on the rear axle though on later models rear discs, hubs and backing plate mounts are metric. Way to mix it up.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby thegreenmachine » April 12th 2013, 2:27am
I found 10mm on the rear axel and 11mm on the front axle. Must be because mines an 03
"that looks legit"
95 AWD Safari money pit
thegreenmachine
Firing on 6 Cylinders (L2)
Years of Membership: thegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full years
Topics: 62
Alias (AKA): Shane a lane
Postby Corsemoto » April 12th 2013, 2:46am
Yeah, you're right now that I think about it, they are 10mm on my '04, still used a box end. Parts breakdown still lists 'em as 5/16 tho...
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby 97cargocrawler » April 12th 2013, 9:38am
Corsemoto wrote:Cargo, you're right it's all standard on the rear axle though on later models rear discs, hubs and backing plate mounts are metric. Way to mix it up.
I was referring more to the U-Joint specs, pinion nut and diff cover hardware. Drives me nuts when they mix that crap up!
Mine were definitely 5/16". Tiny little *******.
97cargocrawler
Topics: 42
Postby Hollywooonj [OP] » April 13th 2013, 5:48pm
Thanks everyone. a friend with the same problem on a JEEP suggested grinding down outer edge of socket so it will seat. Or we could give up since we are replacing whole rear end and we can remove drive shaft by sliding back the rear and then work on u joint on the bench. I got all the other nuts broke loose( shocks, axle, brake, etc) and never thought these would be the headache part of the task.
Hollywooonj
Extra Info: SLE
Postby RECox286 » April 13th 2013, 6:47pm
Have you tried lifting the body of the truck, thus allowing the axle to fall, increasing the angle of the D/S ? That is what I do when
removing the strap bolts. It also helps to put the tranny in neutral, and rotate the shaft so the socket is on the bottom most bolt.
Then lock the shaft in park so you can "break" the bolt. Always use a good 6 point wrench or a six point deep socket with an extension
and a long handled ratchet for good leverage. After a while, it is a no brainer.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby HotWire » February 3rd 2016, 2:11pm
Bringing back a dead thread to vent. This was my evening while trying to determine my axle spline count. I have a friend selling a new in box PowerTrax No-slip. With AWD I can't put tranny in neutral and turn drive shaft.
What a pain!
HotWire
Years of Membership: HotWire has been a member for 5 full yearsHotWire has been a member for 5 full yearsHotWire has been a member for 5 full yearsHotWire has been a member for 5 full yearsHotWire has been a member for 5 full years
Topics: 18
Images: 2
Extra Info: 4.3L V6 AWD
Postby gastropod » February 11th 2016, 8:47pm
Just yesterday I removed these bolts and caps from my 2003 Safari RWD. The heads were "loose" 11mm or whatever a close SAE equivalent would be. Threads are not metric. They look like they might be 8x1, but when I tried to thread an 8x1 nut on them, it only went on a few threads before locking up.
Just checked my '04 rwd, it's the same.
Jon
gastropod
Years of Membership: gastropod has been a member for 6 full yearsgastropod has been a member for 6 full yearsgastropod has been a member for 6 full yearsgastropod has been a member for 6 full yearsgastropod has been a member for 6 full yearsgastropod has been a member for 6 full years
Topics: 17
Extra Info: 2WD SLT
Postby RECox286 » February 11th 2016, 10:34pm
Fer What it's worth dept:
Looking at the pic ^^^ I can make out the code on the top of the bolt heads for an
SAE grade 8 fastener. If it were metric, it would give a numerical code on the
head rather than the hacks. It is therefore an SAE bolt with a head dimension of 5/16"
measured across the flats and you should be using a 5/16" sized wrench even though an
adjustable metric wrench will "kind of fit ." However, as long as you don't draw blood or
crack yer knuckles....Never mind !
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby sfeaver » February 11th 2016, 11:31pm
The "older" vans had a 5/16" head, and some year in the 2000s it became 7/16". Those in the picture look like the 7/16" ones, not metric.
sfeaver
Topics: 29
Images: 21
Postby Leeann_93 » February 17th 2016, 1:20am
Yep, pretty sure mine were 7/16".
Postby SportsBoy » January 5th 2021, 11:38pm
Why don't people replace driveshaft bolts with u bolts like these??? https://www.rockauto.com/en/moreinfo.ph ... 40&jsn=429
I just found these on RockAuto and had no clue they were an option. Seems like a great solution, but I've never seen anyone do it.
I spent hours working my driveshaft to get the bolts out - and one still didn't go - I bent the strap so the ujoint could slip out. If I had u bolts on there it would have taken minutes.
SportsBoy
Topics: 23
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Return to Automatic
It is currently March 6th 2021, 3:06am
Automatic Forum
in Automatic
Date: Mar 01 '21
Time: 7:14pm
AngryPunk
in Automatic
Date: Feb 18 '21
Time: 11:47pm
Youngblood
in Automatic
Date: Jan 15 '21
Time: 1:24am
allenstoltzfus
in Automatic
Date: Jan 14 '21
Time: 7:36pm
runawayjim
in Automatic
Date: Jan 07 '21
Time: 2:09pm
