Tcc plug
Tcc plug
Postby thegreenmachine [OP] » April 15th 2013, 5:53pm
Hello my fellow crazies!
I was at my parents for dinner, ended up talking to my dads neighbor who is a mechanic, I mentioned my shudder at hiway speeds.
He first successfully guesses the type of trans and tells me it's caused by the torque converter being on its way out.
Now he's said as a solution without replacing the tc, is to unplug the Tcc plug at the trans. Says ill still have all 4 gears, just no tc lockup. Says he's been doing it for twenty years.
He was also surprised to know that I knew what trans was in my van, didn't get around to talking about risks or codes related to unplugging, as I had to remove a raccoon from my parents attic. (Btw raccoons are arsholes).
My question is, what are the risks? And how what does lockup mean/do?
"that looks legit"
95 AWD Safari money pit
thegreenmachine
Firing on 6 Cylinders (L2)
Years of Membership: thegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full years
Topics: 62
Alias (AKA): Shane a lane
  • 2001 trans drain plug?
    by keith92ext » December 28th 2020, 3:50pm in Automatic
    December 29th 2020, 8:01pm
    66
    April 18th 2021, 3:49am
Re: Tcc plug
Postby SilverBullet1997 » April 15th 2013, 6:11pm
thegreenmachine wrote:Hello my fellow crazies!
<snip>
Hey watch it, I resemble that remark... :whack:
Alas, Sorry I don't know anything on this subject.... :shrug:
R.I.P.-1997 Astro AWD SilverBullet I 4-9-1997 to 2-17-2015 - Cause of death: Rear-ended
R.I.P.-1999 Astro AWD SilverBullet II 1-4-1999 - July-2016 - Cause of death: Roadrash passenger side
Current: 1999 Astro AWD GreenBullet I - Purchased 02/2018
SilverBullet1997
Years of Membership: SilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full years
Topics: 55
Images: 247
Alias (AKA): Silver or Bullet or SB
Extra Info: 7in Lift AWD Z71
Re: Tcc plug
Postby chevymaher » April 15th 2013, 6:33pm
No risk it just won't lock up if you unplug it. It will work like a old style 350 turbo.
The torque converter is fluid drive so it slips as it works. The lock-up is a clutch inside of the torque converter. It ain't a slippin anymore. Locks it up tight reckon.
Topics: 91
Tcc plug
Postby thegreenmachine [OP] » April 15th 2013, 6:38pm
Wow and it's just that easy folks.
Hmm. Wonder if my cruise control will still function......
"that looks legit"
thegreenmachine
Topics: 62
Re: Tcc plug
Postby chevymaher » April 15th 2013, 6:44pm
thegreenmachine wrote:Wow and it's just that easy folks.
Check it out and report back.
I a wagering it works.
Topics: 91
Re: Tcc plug
Postby SilverBullet1997 » April 15th 2013, 7:00pm
Yes, we will use you as our trail and error :D
SilverBullet1997
Topics: 55
Images: 247
Tcc plug
Postby thegreenmachine [OP] » April 16th 2013, 1:54am
Always a bridesmaid.......
Will be driving on the hiway tomorrow. I've already done the trans filter and added dr tranny anti shudder about two weeks ago. As well as Lucas something something.
First actual hiway trip since the shudder started. If it happens on the way to work ill pull the wires and see what happens.
"that looks legit"
thegreenmachine
Topics: 62
Re: Tcc plug
Postby icebrrg3rd » April 16th 2013, 3:09pm
The two downsides to unplugging it are reduced mpg & higher trans fluid temps. By not locking up, there will always be a small amount of slip, so you will not get the best mpg possible. Plus all that slip will increase the trans temp, but if you have an external cooler added it shouldn't be an issue. That is what I've heard, but if it's on the interweb, you know it's true...
-Andrew
icebrrg3rd
Topics: 50
Alias (AKA): Andrew
Van Model Year: 1991
Re: Tcc plug
Postby 97cargocrawler » April 16th 2013, 10:00pm
Andrew nailed it. Ideally you want the TCC to lock up ASAP as this is what gives you the best mpg and power to the wheels. Though depending on your driving (stop and go etc.) it doesn't usually stay locked for very long. I think long highway drives where it would typically remain locked is where your higher temps will come into play. Unless you have a temp gauge (analog from the trans or digital through the OBD port) I would be very careful. Your nose will come in handy....my experience is you can always smell trans trouble.
I'd try it and if it works consider it a temporary fix. The TCC replacement is like a 4 hour job by yourself...maybe 2 with a buddy and the right tools....and flat ground.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Tcc plug
Postby thegreenmachine [OP] » April 17th 2013, 1:14am
Update.
After 600km on new filter and dr tranny, Lucas something, shudder has come back.
I don't like the way it feels so I pulled off the hiway and back-roaded it home.
I rather not run the risk of roasting a newish tranny. Po replaced at 180,000km, now has 230,000km. Obviously didn't replace the converter at the same time.
Darn. People that don't maintain their vehicles, piss me off.
"that looks legit"
thegreenmachine
Topics: 62
Return to Automatic
It is currently April 18th 2021, 3:49am
Automatic Forum
Bikley
in Automatic
Date: Mar 29 '21
Time: 5:42am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:49am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:42am
in Automatic
Date: Mar 01 '21
Time: 7:14pm
AngryPunk
in Automatic
Date: Feb 18 '21
Time: 11:47pm
