Change automatic transmission fluid? - 2004 w/87K
Postby michael_aos [OP] » May 9th 2013, 5:38am
II bought it in April 2010 w/~78.5K - so averaging around 3K/yr.
It's not clear what maintenance was done before I bought it. CARFAX has some info, but not very detailed.
I've generally been staying on top of scheduled & preventative maintenance.
Just had the oil changed @ 87K and they recommended a $255 transmission flush. I had been planning to wait until the 90K service (potentially another year) to have the fluid changed.
Any suggestions on the proper next-step?
michael_aos
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: michael_aos has been a member for 10 full yearsmichael_aos has been a member for 10 full yearsmichael_aos has been a member for 10 full yearsmichael_aos has been a member for 10 full yearsmichael_aos has been a member for 10 full yearsmichael_aos has been a member for 10 full yearsmichael_aos has been a member for 10 full yearsmichael_aos has been a member for 10 full yearsmichael_aos has been a member for 10 full yearsmichael_aos has been a member for 10 full years
Topics: 13
Alias (AKA): Michael Aos
  • number 2 on automatic transmission shifter
    by Olivier02 » June 13th 2020, 9:22pm in Automatic
    Last post by SportsBoy View the latest post
    June 14th 2020, 12:51am
  • Transmission oil cooler leaks
    by Rod's Trucks » April 14th 2020, 8:20pm in Automatic
    Last post by MmusicmanMmusicman is online! View the latest post
    April 22nd 2020, 2:03am
    66
    September 23rd 2020, 5:19pm
Re: Change automatic transmission fluid? - 2004 w/87K
Postby Rayvan » May 9th 2013, 4:49pm
Have the trans service done at 90,000, not just a flush. Service includes dropping/cleaning the pan and filter replacement. A flush isn't enough.
Rayvan
Years of Membership: Rayvan has been a member for 12 full yearsRayvan has been a member for 12 full yearsRayvan has been a member for 12 full yearsRayvan has been a member for 12 full yearsRayvan has been a member for 12 full yearsRayvan has been a member for 12 full yearsRayvan has been a member for 12 full yearsRayvan has been a member for 12 full yearsRayvan has been a member for 12 full yearsRayvan has been a member for 12 full yearsRayvan has been a member for 12 full yearsRayvan has been a member for 12 full years
Postby Mr_Roboto » May 9th 2013, 9:18pm
255 seems REALLY high for just a flush quite frankly.
Mr_Roboto
Firing on 1 Cylinder (L2)
Years of Membership: Mr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full yearsMr_Roboto has been a member for 12 full years
Topics: 51
Postby Leeann_93 » May 10th 2013, 12:30am
Absolutely not a tranny flush. Have a service done where the pan is dropped and the filter is changed.
Most places want to do just a flush because they can use their fluid machine, which doesn't require anyone with a brain to operate.
Return to Automatic
It is currently September 23rd 2020, 5:19pm
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
