95 front driveshaft delete
Postby Soontobeavanowner [OP] » May 9th 2013, 2:00pm
So I read a while ago that I could remove it, but, I would have to re-attach part of it to save the diff or TC from burning up. Can anyone help me with this?
I know about the rolling; where I am is mostly flat.. The driveshaft threw a weight and I'd like to just swap the TC eventually. Just need to get this off till then so I can stop spending all my money on fuel.
Soontobeavanowner
Years of Membership: Soontobeavanowner has been a member for 7 full yearsSoontobeavanowner has been a member for 7 full yearsSoontobeavanowner has been a member for 7 full yearsSoontobeavanowner has been a member for 7 full yearsSoontobeavanowner has been a member for 7 full yearsSoontobeavanowner has been a member for 7 full yearsSoontobeavanowner has been a member for 7 full years
Topics: 5
Re: 95 front driveshaft delete
Postby Soontobeavanowner [OP] » May 9th 2013, 2:15pm
This may have answered all my questions actually.
https://sites.google.com/site/astrosafa ... etrain/awd
Soontobeavanowner
Topics: 5
Postby Soontobeavanowner [OP] » May 9th 2013, 2:17pm
It says "keep the wheels off the ground to avoid damage" at one point, does this mean I can't remove the shaft while using ramps vs jack stands?
Soontobeavanowner
Topics: 5
Postby Leeann_93 » May 10th 2013, 12:31am
Have it on stands, not ramps.
And this really will make no difference in your fuel consumption.
Postby Soontobeavanowner [OP] » May 22nd 2013, 3:08am
Really? I've heard 2wd is way better than awd and i also figured since the shaft isn't balanced it would be working harder too..
Soontobeavanowner
Topics: 5
Postby Leeann_93 » May 22nd 2013, 3:12am
You still have the weight of the differential, cv axles, torsion bars and transfer case.
Postby tedanderson » May 22nd 2013, 3:49am
Ditto. Unless you swap the entire subframe assembly, its still an AWD van.
tedanderson
Firing on 8 Cylinders (L3)
Topics: 76
Alias (AKA): 2Big4aMiniVan
Return to Automatic
It is currently November 28th 2020, 1:00pm
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
