shifter issues
shifter issues
Postby Black89cs [OP] » February 7th 2009, 10:36am
On my van I happened to notice that when shifting out of park and down to overdrive it works just fine, but if I try to shift down any farther it won't budge. It barely goes into 3rd, but after that the shifter seems to be stuck. When driving it shifts gears ok, and neutral, reverse, park, overdrive positions work fine, although slightly out of allignment with the needle on the indicator. I know the transmission was replaced at some point by the previous owner. Does the cable/linkage need adjusted, or is it binding up on something either underneath or inside the van?
Black89cs
Firing on 8 Cylinders (L1)
Years of Membership: Black89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full yearsBlack89cs has been a member for 11 full years
Topics: 81
  • number 2 on automatic transmission shifter
    by Olivier02 » June 13th 2020, 9:22pm in Automatic
    Last post by SportsBoy View the latest post
    June 14th 2020, 12:51am
    7
    56
    September 23rd 2020, 4:35pm
Re: shifter issues
Postby astro355 » February 7th 2009, 10:42am
I would check for binding under the van. Either the linkage or the pivot point on the frame.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Re: shifter issues
Postby Black89cs [OP] » February 7th 2009, 10:43am
Ok ,thanks. Now I'll have to either wait until the ground is dry enough or kick one of the cars out of the carport for a bit to check things out. :mrgreen:
Black89cs
Topics: 81
Return to Automatic
It is currently September 23rd 2020, 4:35pm
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
MmusicmanMmusicman is online!
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
