2000 astro no awd drives great no light or noise help
Postby adamacc10 [OP] » June 3rd 2013, 11:14pm
I have a 2000 Astro van and the all-wheel-drive is not working. I got stuck in an inch of mud and the only wheel that is turning is the passenger rear wheel. all driveshafts are there and the transfer case but it is still not working I checked all the fluids and they are full and look good any help would be appreciated. do you think that it could be the transfer case motor or do you think I need a whole new transfer case also do you think it is alright to drive like it is?
adamacc10
Years of Membership: adamacc10 has been a member for 7 full yearsadamacc10 has been a member for 7 full yearsadamacc10 has been a member for 7 full yearsadamacc10 has been a member for 7 full yearsadamacc10 has been a member for 7 full yearsadamacc10 has been a member for 7 full yearsadamacc10 has been a member for 7 full years
Alias (AKA): Sirclark
Extra Info: 4.3 awd
  • 2005 Astro awd trans interchange?
    by offroad safari » May 23rd 2020, 3:39am in Automatic
    Last post by lllharris View the latest post
    May 23rd 2020, 12:05pm
  • newby I screwed up park/neutral switch please help
    by jmoe » April 30th 2020, 4:17pm in Automatic
    May 9th 2020, 4:53am
    36
    October 27th 2020, 3:50pm
Re: 2000 astro no awd drives great no light or noise help
Postby adamacc10 [OP] » June 3rd 2013, 11:29pm
Just in case you going to ask the light does come on when you start the car for a couple seconds and then goes off like normal then there is no light after that
adamacc10
Extra Info: 4.3 awd
Postby thegreenmachine » June 4th 2013, 12:10am
The service Awd won't always light up if the encoder motor is malfunctioning. The computer can read that the encoder motor is engaging, where in fact it could be the gears in the motor are stripped, this giving a false engagement reading.
Drop the driveshaft to access the last of the three encoder motor bolts.
Use a 9/16's wrench to turn the cam that switches from 2hi to 4hi.
I feel like I've answered this question numerous times.
"that looks legit"
95 AWD Safari money pit
thegreenmachine
Firing on 6 Cylinders (L2)
Years of Membership: thegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full years
Topics: 62
Alias (AKA): Shane a lane
Postby adamacc10 [OP] » June 4th 2013, 12:13am
Ok I will try this in a couple of days when I can get it on a hoist. Is it ok to drive like this until then even if its not that. ie ( clutches)
adamacc10
Extra Info: 4.3 awd
Postby DRZ » June 4th 2013, 12:50am
yes
DRZ
Firing on 5 Cylinders (L2)
Years of Membership: DRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full years
Topics: 53
Images: 55
Alias (AKA): HPbyStan
Extra Info: awd cargo Alloys
Postby thegreenmachine » June 4th 2013, 12:52am
Pull the atc fuse if your worried. Kills the power to the encoder motor.
"that looks legit"
thegreenmachine
Topics: 62
Postby adamacc10 [OP] » June 4th 2013, 12:59am
Anything else I can try while under there to narrow it down if it isn't the encoder
adamacc10
Extra Info: 4.3 awd
Postby thegreenmachine » June 4th 2013, 4:39am
Anything else I can think of is going to make a lot of noise, and feel broken while driving. It's easy to check it you have the right tools. If I had money to gamble I'd make the encoder motor call every time, because you aren't complaining about noise, smells, vibration, or clunking.
If you use the search function, you'll find a bunch of threads about it.
"that looks legit"
thegreenmachine
Topics: 62
Postby Drummernaut » June 4th 2013, 6:13am
You can measure the motor. Look for around .5 to 50 ohms.
Remove the wire and use a meter on the terminals.
1999 Astro LT AWD
MODS: Electric fan, Transmission cooler/fan, AWD engaged LED
Drummernaut
Years of Membership: Drummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full years
Topics: 9
Alias (AKA): Drummer From Hell
Extra Info: LT V6 AWD
Return to Automatic
It is currently October 27th 2020, 3:50pm
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
