noisey Trans
noisey Trans
Postby window5 [OP] » March 8th 2009, 7:30pm
hi everyone i am new here and need some help. i have a 2000 safari van 130k miles on it and when i put the van in gear i get a loud whirring noise, the noise gets louder as i go down the road untill it goes into the final drive gear then it goes away. the van has also started to surge when stopped at idle speed but in gear at a light. the van has a 4.3 and is 2wd. thanks for any help or suggestions.
Paul
window5
Years of Membership: window5 has been a member for 11 full yearswindow5 has been a member for 11 full yearswindow5 has been a member for 11 full yearswindow5 has been a member for 11 full yearswindow5 has been a member for 11 full yearswindow5 has been a member for 11 full yearswindow5 has been a member for 11 full yearswindow5 has been a member for 11 full yearswindow5 has been a member for 11 full yearswindow5 has been a member for 11 full yearswindow5 has been a member for 11 full years
  • 2005 Astro awd trans interchange?
    by offroad safari » May 23rd 2020, 3:39am in Automatic
    Last post by lllharris View the latest post
    May 23rd 2020, 12:05pm
  • Trans Removal Crossmember Question
    by Huckleberry » May 31st 2020, 9:14pm in Automatic
    May 31st 2020, 10:47pm
    7
    26
    October 22nd 2020, 7:07am
Re: noisey Trans
Postby tnhillbilly » March 8th 2009, 7:51pm
Hi and welcome to the forum. When was the last time the transmission fluid and filter was changed? I had this to happen on a Ford Escort and my dads little Geo Metro. They had been neglected for well over 100,000 miles with no fluid or filter change. A filter and a flush fixed both of them. If this is your case and it is that bad it may need a flush to get all the old fluid out. That is just my :2: . I am sure others will give their input when they can.
1996 Safari high top conversion rwd 175,000 miles original engine, tranny, and rear end.
tnhillbilly
Years of Membership: tnhillbilly has been a member for 11 full yearstnhillbilly has been a member for 11 full yearstnhillbilly has been a member for 11 full yearstnhillbilly has been a member for 11 full yearstnhillbilly has been a member for 11 full yearstnhillbilly has been a member for 11 full yearstnhillbilly has been a member for 11 full yearstnhillbilly has been a member for 11 full yearstnhillbilly has been a member for 11 full yearstnhillbilly has been a member for 11 full yearstnhillbilly has been a member for 11 full years
Topics: 22
Re: noisey Trans
Postby window5 [OP] » March 8th 2009, 8:50pm
sounds good and thats why i am asking about the noise. I just had a machine flush and fill about 6 months ago.300.00
Thanks paul
window5
Re: noisey Trans
Postby tnhillbilly » March 8th 2009, 9:25pm
If that's the case you shouldn't need another one. Was the filter changed? If not you may need to do that. I don't usually recommend an additive but my transmission mechanic (certified local guy that has been in business for years) swears by a product called lubeguard. It is in a red bottle (for gm's). I have used it before with good results. It was put in my Safari about a week ago also. Something you might want to look into.
tnhillbilly
Topics: 22
Re: noisey Trans
Postby window5 [OP] » March 8th 2009, 9:45pm
Thanks for the help, i will look up the lubeguard it can't hurt. i am hoping its not something with the torque converter or anything expensive. my wife loves her van and doesnt want anything new. this goes to all the soccer and baseball games and has always been reliable.
thanks paul
window5
Re: noisey Trans
Postby Matrixx » March 9th 2009, 4:29am
Hi window5
Welcome to the Forum
Is the fluid level up where it should be "hot"?
Have the engine warmed up and idling (in Park, emergency brake on, and on level ground), then pull the transmission dip stick out, wipe it off, put it back in, then pull it out again and have a look at what it indicates. It should be in between the Hatched Hot Mark.
If it's fine, then do as others have recommended. Make sure you use the correct Transmission fluid (Dexron(R) III or better), that will mess things up as well. Some updates on transmission fluids to be made aware of:
http://en.wikipedia.org/wiki/DEXRON
Hope this helps. Please keep us updated, Thanks.:)
Matrixx
Re: noisey Trans
Postby window5 [OP] » March 9th 2009, 5:42pm
thanks for all the help i am going back to the shop that did the work and will keep you advised of the progress.
Thanks Paul
window5
Re: noisey Trans
Postby window5 [OP] » March 10th 2009, 11:56pm
update/ costly. i went to three different places including the dealer and all had the same diagnosis. needs a new torque converter. cheapest estimate is 850.00 but all suggest a complete rebuild which is 1850.00 does this sound reasonable. the van is only worth 3500-4000. what to do??? bought beer thats as far as i got. thinking of trading it in. please share thoughts and suggestions. thanks Paul
window5
Return to Automatic
It is currently October 22nd 2020, 7:07am
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
