What tranny type do I have?
Postby cosmoyogiman [OP] » May 12th 2009, 1:46am
Hi. I have a 1990 4.3 TBI 2wd. I need to know the tranny type (4L60E, 4L80E, other) so I will know what MIL code chart to look at. Thanks.
cosmoyogiman
Years of Membership: cosmoyogiman has been a member for 12 full yearscosmoyogiman has been a member for 12 full yearscosmoyogiman has been a member for 12 full yearscosmoyogiman has been a member for 12 full yearscosmoyogiman has been a member for 12 full yearscosmoyogiman has been a member for 12 full yearscosmoyogiman has been a member for 12 full yearscosmoyogiman has been a member for 12 full yearscosmoyogiman has been a member for 12 full yearscosmoyogiman has been a member for 12 full yearscosmoyogiman has been a member for 12 full yearscosmoyogiman has been a member for 12 full years
Topics: 12
Alias (AKA): Doug
Extra Info: 4.3L RWD V6
Re: What tranny type do I have?
Postby 'cudapaul » May 12th 2009, 2:09am
For the 1990 year it is a 700R4, or also called a 4L60.
Do not confuse it with the 4L60E (later model years) which is electronically controlled by the ECM.
'cudapaul
Years of Membership: 'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years
Alias (AKA): 'cudapaul
Extra Info: LT AWD
Postby cosmoyogiman [OP] » May 12th 2009, 2:50am
I just found a big MD8 on the side, but need to know if it is 4L60E, 4L80E or other
cosmoyogiman
Topics: 12
Alias (AKA): Doug
Postby 'cudapaul » May 12th 2009, 3:24am
I just told you. It is a 700R4, same as 4L60.
'cudapaul
Extra Info: LT AWD
Postby webcat » May 12th 2009, 3:35am
like cudapal said , you have a 700R4
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Postby cosmoyogiman [OP] » May 12th 2009, 3:41am
thanks. I added my last post before I saw your answer. OOOOOOOOOOps. :)
cosmoyogiman
Topics: 12
Alias (AKA): Doug
Postby 'cudapaul » May 12th 2009, 4:10am
No problem!
Just remember your van has OBD1, not OBD2 (1996 and later).
'cudapaul
Extra Info: LT AWD
Postby cosmoyogiman [OP] » May 12th 2009, 5:12am
ok thanks.....but what does OBD1 refer to?
cosmoyogiman
Topics: 12
Alias (AKA): Doug
Postby 'cudapaul » May 12th 2009, 6:52am
It is called On Board Diagnostics 1 v. On Board Diagnostics 2.
The first versions were basic and monitored just a few things, enough to aid basic troubleshooting. GM's version is called ADL.
The seconds version is JAE standardized and is very comprehensive in diagnostics, it can almost point you directly to a component failure.
You can do a google search on either OBD1 or OBD2 and probably find more info than you will EVER want to know!
'cudapaul
Extra Info: LT AWD
Postby cosmoyogiman [OP] » May 12th 2009, 8:36pm
ok thanks for that info
cosmoyogiman
Topics: 12
Alias (AKA): Doug
Return to Automatic
It is currently April 17th 2021, 3:09am
Automatic Forum
Bikley
in Automatic
Date: Mar 29 '21
Time: 5:42am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:49am
95AstroLT
in Automatic
Comments: 19
Date: Mar 06 '21
Time: 3:42am
in Automatic
Date: Mar 01 '21
Time: 7:14pm
AngryPunk
in Automatic
Date: Feb 18 '21
Time: 11:47pm
