tranny cooler brands
Postby fungus2k [OP] » May 29th 2009, 2:06am
just wondering what brands of tranny coolers people here have used, and your opinions on which one i should look into. I am thinking about putting one in, even though i don't do any towing, the additional cooling capacity will put my mind at ease.
fungus2k
Years of Membership: fungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full yearsfungus2k has been a member for 12 full years
  • Tranny cooler install help
    by Chunkstyle » August 11th 2020, 11:13pm in Automatic
    August 14th 2020, 12:06am
  • 07 Colorado tranny in 00 Astro
    by dasvigo » July 5th 2020, 4:56am in Automatic
    July 6th 2020, 11:18pm
    October 28th 2020, 6:11pm
Re: tranny cooler brands
Postby Matrixx » May 29th 2009, 5:00am
The most popular brand is Tru-Cool Stacked Plate coolers from the old forum and current members.
http://www.transmissioncoolers.us/Merch ... creen=SFNT
Matrixx
Postby Mr_Bowtie » May 29th 2009, 6:17am
Not sure what brand is on my Van as it was already on there. But, I have had really good luck with B&M Tranny coolers. Easy to install and definatly make a difference. :mrgreen:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby Leeann_93 » May 30th 2009, 8:53am
The guys on the Blazer forums swear by the B&M supercoolers - for one, they have a viscosity bypass so they don't overcool in cold weather.
Postby astro355 » May 30th 2009, 8:46pm
I really think the best tranny cooler you can get isn't even a tranny cooler. Just get an aluminum transmission pan. Several companies make them and they aren't too expensive. They have a higher fluid capacity holding 2 to 3 more quarts and have fins on the bottom of them to dissipate the heat. Plus no extra lines to run if you plan on using the stock cooler.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby Mr_Bowtie » May 31st 2009, 2:25am
You also forgot it makes filter/fluid changes easier with its integrated drain plug! :mrgreen:
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Postby astro355 » May 31st 2009, 3:14am
P71CVMAN wrote:You also forgot it makes filter/fluid changes easier with its integrated drain plug! :mrgreen:
Thats very true. I know GM wanted it cheap, but I just didn't get why they didn't put drain plugs on ever component that held fluid.
astro355
Postby Leeann_93 » May 31st 2009, 3:29am
Manufacturers didn't do that. It's incredibly stupid, I agree. I added a deep aluminum pan with drain plug to my '73 motorhome (Dodge 440 with 727) and it's been the best thing I've ever done. What a mess-saver (and major time-saver, too).
But when it's time to change the fluid and filter on both the Bravada and the Astro, I'll be adding a drain plug at the very least.
Postby fungus2k [OP] » May 31st 2009, 3:58am
i saw the larger drain pan as well, but could only find them for 150ish, and the cooler was about 50 bucks, which one do you guys think works better?
fungus2k
Postby astro355 » May 31st 2009, 5:57am
I have seen ads claiming anywhere from 20 to 50 degrees in decreased heat. The only sure way to know is to have a trans temp gauge installed with the pan. Even the cheaper steel ones will work if they have the cooling tubes mounted on the bottom.
But I can tell you that at school we did an experiment in our automatic transmission class. We welded 4 fins onto the pan of a 700R4. Each fin was just bar stock that was 3/4" wide and the 10" long. We measured a drop of 25ish* while the trans was on a trans dyno when a cooling fan was blown across it. They do work.
astro355
Postby Mr_Bowtie » June 1st 2009, 3:19am
^Thats a huge difference in temp......good to know. A cool tranny is a happy tranny......... :lol:
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Return to Automatic
It is currently October 28th 2020, 6:11pm
Automatic Forum
Chunkstyle
in Automatic
Date: Aug 11 '20
Time: 8:25pm
in Automatic
Date: Jul 26 '20
Time: 1:22pm
Olivier02
in Automatic
Date: Jun 13 '20
Time: 9:22pm
SoccerMom4x4
in Automatic
Date: Jun 12 '20
Time: 2:50pm
SoccerMom4x4
in Automatic
Date: Jun 11 '20
Time: 2:12pm
Users browsing this forum: Google Adsense [Bot] and 6 guests
